Deck Height
- 73fback
Deck Height
I cc'd my heads today for the second time to insure the accuracy. Both heads have 1 @ 48 and 1 @ 49 cc's. My question is, if I use deck height spacers to set my CR, it would require a different spacer on each cylinder of the same head. Won't this cause sealing problems?
I'm also familiar with the technique of shaving some off to gain the extra cc, but I'm a little nervous about doing this.
Also, is this one cc enough to even worry about?
- sparkmaster1
- sparkmaster1
Ordinarily you shouldn't shim differently on the same side unless you're correcting for uneven barrel length or case decking - with both barrels clamped down lay a straightedge across the top and make sure it contacts all 4 points (well, within .001" or so anyway).
At ~7.5:1, 1cc is going to make approximately 0.1 difference in the compression ratio which is at the limit of acceptability for a stocker IMO. Ideally you should open up the smaller chamber a little to get them closer but I wouldn't lose any sleep over it if you don't.
Note that if you have a reground intake valve in the larger chamber, replacing it with a new one would help (~¼cc for every .010" thicker the valve is).
Lymkey930
deck height
- 73fback
To be honest, part of why I'm worried about it, besides the fact I want it to run as good as possible, is bragging rights
I have some buddies who are looking to buy engines, wether through mail order or locally. I have been spreading the advice of many, and that is to do it yourself, you are your best mechanic. Well, I believe this statement, and this is my first full rebuild.
I just want to prove a point to a handful of buddies, and have as close to perfect specs as I can. Even a bonehead like myself can do this.
BenI
I once replaced a jug and forgot to replace the shim-immediatly I heard a whistling sound on startup. I tried to convince myself that it was a ring seating sound but had to face reality when the sound got worse as I drove the car more. Finally I pulled the head and found that the missing shim had caused the head to sit crooked causing really nice head leaks.
First thing I do after torquing down a head is airload each cylinder and run around the head/cylinder parting line with a lit paper match - any flickering tells you something ain't right; it only takes a couple minutes to check and it's much nicer to find the bad news at that point rather than after it's in the car.BenI wrote:I once replaced a jug...had caused the head to sit crooked causing really nice head leaks.
