Big Wasser?
Big Wasser?
Berg actually makes WBX cranks and references some "big bore" kits out of Germany.
Surprised me as well that Berg does these cranks.
Adrian Pillow
'66 VW Westfalia
'79 Porsche 911 SC - FS
VolkSport Kafer Gruppe
Adrian Pillow
'66 VW Westfalia
Big Wasser?
I have no problem getting a crank made, I just need to know what fits (within reason), what rods to use, and what pistons....
I want to build this without it taking forever as I find what does NOT fit.
John
Aircooled.Net Inc.
John
Aircooled.Net Inc.
Big Wasser?
I think it is Mahle that makes 98 mm. pistons & cylinders for use along with an 82 mm stroke. (2474 cc) At least they used to.
John, if you want me to, I will check into it. just let me know.
- Tom Notch
Big Wasser?
I believe that is what Gene Berg built for his Vanagon, 98x 82 or was it 96x86? Could ask them. I've ridden in that Vanagon, Ohmigod power! And cruzes with all the current crop of minivans out across the desert.
Tom Notch
Tom's Old VW Home
Tom Notch
Tom's Old VW Home
Big Wasser?
Yes, please check into it! TIA
(mine has a T3 going onto it too)
John
John
Big Wasser?
OK Guys, I know a lot about the aircooled, and a bit about the waterboxer. I want to build a larger (not stupid big) wasserboxer. Would someone that KNOWS (no guessing, I can guess as good as anyone) please post what to do? I think I can go with 95s by boring the cylinders (where to get pistons; I may design some squishies for this application, it would be perfect), what stroke and rods do I use, etc. I'm going to port the heads, and put our turbo kit on it, with a special cam, I just need help with the crank/rod/piston area, I know you can't shim as easily as the aircooled!
John
Aircooled.Net Inc.
John
Aircooled.Net Inc.
Big Wasser?
The biggest one can go is 101.6mm. custom sleeves and custom pistons.
use the stock crank and its 2476 ccm.
You need alot of dish in the pistons, buts it no problem.
And yes its been tested... at 28psi of boost.
Carsten
Carsten
- Steve C
Big Wasser?
Hi
Freind of mine showed me some 96s out of a 2.7 deisel Toyota HiLux, they looked like they would fit. There is some Ford pistons on the wiseco site, they 4.020 (102.1 mm) # K272A2, they might be worth looking at. Check out truck supplies, they can usually get diffrent size liners.
Steve C
Steve C
- Steve C
Big Wasser?
Hi
Just had another thought, why not use some type 4 barrels & pistons, and turn the fins down a bit, Im not sure if the barrels are long enough.
Steve C
Steve C
Big Wasser?
Personally I wouldn't bother going to the trouble of making it as big as possible, a well built 2.1 turbo with the right ancillaries can easily make 300hp, more if you're brave
It'a just a matter of controlling the fueling and desiging an exhaust that will work with the turbo
Big Wasser?
I heard someone used 97mm Porsche pistons...
Yeah how much work to make a set of type1 or 4 barrels fit with the fins removed?
Si
Si
Big Wasser?
I actually looked at some cylinders last night I had here. I think 96s would be cake, bore the stock liners out. The problem is piston dish. I may have to look at these for a few weeks and come up with a squishy for the wasserboxer head!
John
Aircooled.Net Inc.
John
Aircooled.Net Inc.
- Muffler Mike
Big Wasser?
i have no idea if they would work but have you looked at Jack's 101's that are suposedly set up for the t1 spacing? no clue what the bolt pattern would be.
Muffler Mike
www.MufflerMike.com
Muffler Mike
www.MufflerMike.com
Big Wasser?
John:
You might check with Bob @ Boston Engine. He has a lot of good things said about him on the Vanagon and Syncro lists.. They have a web site http://www.bostonengine.com/
HTH
[This message has been edited by PapaG (edited 02-05-2003).]
HTH
Big Wasser?
This guy has been doing oxys for years -I found this before i even found morten's site 2 years ago. I don't know who was first but this guy has lotsa info on wassers and oxys and how to build some reliable CCs into a wasser-check this one out! http://www.geocities.com/motorcity/9008/indexe.html
