Ok, looking for knowledge:
Is the T5 crank interchangeable with the T4 crank, or is it unique to the T5?
I am from the Government, and I am here to help!
T5 crank interchangeable?
Hello,
It is different from either Type I or Type IV.
These Cranks can be found in the late model vanagen Wasserboxer motors.
69 and 76 stroke from the factory.
- Joe
- Joe
Tom Notch is running a Type I crank W/ Type IV mains (Berg).
He's going to create an adapter for the main seal to sleeve it down from Type IV to Type I size.
- Joe
- Joe
We have made a adapter for a T-1 rear main seal into a h2o boxer case if you run a bug style crank & flywheel, with a o-ring around the outside of the alum. adapter no leaks,You put it in when you put case halfs together. Thanks Rocky
- Class 11 streeter
Ok, crank is unique to the T5, unless case is modified to use a T1.
Got it.
Got it.
Actually the case needs no Mods, you need a Type I crank with Type IV mains.
- And the seal adapter Rocky mentioned...
I preffer to run the Wasser crank (stock or stroked) that way you can keep the 5 bolt TypeIV style flywheel atachment.
- Joe
[This message has been edited by Type 5 Joe (edited 01-20-2003).]
- Joe
- Bobby74
Is it possible to use shouldered bolts or is 5 pinning overkill?
I just use new bolts, you could add the 5 extra dowells....
I've never had a flywheel come loose, I have busted a couple ring & pinions...
- Joe
- Joe
