I'm practicing building a 2180cc type 1 motor before I build my 2276 turbo monster. I'm up to the point where I check the rotating assembly for clearance, and everything clears except this one point. My question is: Do I take material off the rods, or off the cam? I haven't had the assembly dynamically balanced yet.
Case: AS41 from my previous 2180 engine
Crank: GEX welded/counterweighted 82mm
Rods: Reconditioned stock VW
Cam: Engle W125
You can clearance the cam on a bench grinder and not have to worrie with the rods....Stock rods also have some clearance issues--Is why I use scat I-beams to help with clearance issues....The nice thing about clearanceing the cam instead of the rods is no rebalceing.....
Leave the rods alone. Five minutes with a die grinder and the cam is clearanced. Bench grinder and lath take longer My Weber and Rimco stroker rods did not need the cam to be clearanced. I installed Rev Master I beams and it needed quite a bit. The stock rod bolts and nuts might be a weak point. At this point it would be worth the money to get a set of CB H beam rods. Once you subtract the price of the ARP 200 bolts from the price they are the same price as the Unitechs.
