Difference in IDF's and IDA's
- James2
Difference in IDF\'s and IDA\'s
about 400 bucks
- Veedubber63
Hey, I have a question and it probably has been asked before. What is the difference in the Weber IDF"S and the Weber IDA's?
Thanks,
J.W.
Thanks,
J.W.
vicsvw
IDA's are just for racing and have no low speed circuit. Very Old but good design for all out power. IDF's have the idle circuit and can be purchased in the 48's Vic. www.1800vw.com
Vic. http://www.1800vw.com
[This message has been edited by vicsvw (edited 01-12-2003).]
Cpt Zoomy
Race only? I run IDA's on the street without a problem. You need to drill a third progression hole that's all.
Rob Roetman
I put 1200 miles on my bug in 4 days last summer with IDAs. They even ran good going up a 11,300 foot mountain pass. I do have the 3rd hole.
- Drake
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Rob Roetman:
...I do have the 3rd hole. <HR></BLOCKQUOTE>
Thats awfully personal information to be placing on a public web site dont you think
Drake
'63 Bug "Christine"
'72 Square "Ginger"
There are 10 types of people in the world, those that understand binary and those that don't.
Drake
'63 Bug "Christine"
'72 Square "Ginger"
IDFs use a rubber-diaphragm accelerator pump like "most" carbs; IDAs use a metal-in-metal piston pump so they can handle any fuel without worries of the diaphragms rotting.
Also the manifolds are different, the IDA's throttle bores are further apart than IDF/DRLAs'.
- Veedubber63
Thanks for the info. But I still have a couple question. Which is the better carb the IDF of the IDA? Also, What is the displacement that I can the IDA's on? One last question, On Carbs of this size which are the btter carbs Webers of Kadrons?
Thanks again,
J.W.
Thanks again,
J.W.
- James2
one is not better then the other, one is better for some applications and one is better for other applications.
Also, You are asking us to compare a $300 set of kadrons witha $1200 set of IDAs.
Why don't you give us an idea about your engine and how you will use it. Then you can get an intelligent answer.
JohnConnolly
read the carb article in the tech section at www.aircooled.net that will give you the answer you seek grasshopper.
John
Aircooled.Net Inc.
John
Aircooled.Net Inc.
