CR vs Octane rating?
- 71Vdubber
Hi,
has anyone seen on the web, or know off hand, some sort of chart or graph that gives a correlation of compresstion ratio to octane rating for a VW engine?
Over here 95 octane unleaded is standard and 98 is premium, and I am trying to work out the optimum compression ratio.
Its impossible to calculate the octane needed from static CR, you must know the dynamic compression ratio, and even then every engine is different....
Gene Bergs program says that my 12.15:1 CR 2332(222BHP@8500) should have to run 120 octane, thats weird because it wants 30 degrees full advance on 93 octane..
I suppose you're looking for something like this: http://www.btinternet.com/~mezporting/compression.html
For a STOCK Type I engine it comes very close to my experience, but note all of the disclaimers - like Jake says, every engine combination is different.
Do you use the (R+M)/2 octane rating system? if not you'll have to compensate for that.
74baja1915
That site said i need 115 octane!!!!???!?!?!?!
If its not broke don't fix it, but if it can be made better by all means do it!
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by 74baja1915:
<B>That site said i need 115 octane!!!!???!?!?!?!
</B><HR></BLOCKQUOTE>
At 10:1, yes it will. It also says you can run 87 (R+M)/2 at up to 7.6:1 and need better than 91 by 8:1.
Note that it was created by a motorcycle tuner who specializes in endurance racing engines (sustained WOT with an aircooled engine) so it will be more conservative than a typical waterpumper or "part-time" high performance engine. Again, read the disclaimers.
- James2
I only need 101 Octane.
- Searoy
I need 127.
*** Teach a Man to Fish ***
Darth Searoy
"I tend to lean toward a tighter gap and a
looser skirt....a little slap never hurt." --
Joe Locicero a.k.a. Joe of the West
Darth Searoy
- 71Vdubber
Thanks for that, It's a start!
- Mitch
Depends on what cam you run!
- 71Vdubber
I've got flycut 56cc ported polished, blended semi-hemi 040 heads, 90.5mm pistons and an engle 110 cam with a 009 dizzy.
If I set the deck height at .040" then I'll get a compression ratio of 8.1, sound ok?
- Eaallred
Wow, it says i'm going to need 156 octane for mine!
LOL
Eric
64 Bug
64 Bus
LOL
Eric
64 Bug
64 Bus
- jasonb
This program is no more accurate for us than using a magic eightball.
At a very minnimum you would need the valve timing events of your cam to get a worthwhile answer to the question of octane vs cr.
Even better (but nigh impossible) would be accurate VE numbers for your engine.
- Mitch
Who has the formulas for Static and Dynamic compression with different cams vs octane?
- jasonb
There's a calculator at http://www.rbracing-rsr.com/comprAdvHD.htm which will calculate your dynamic compression including altitude and boost. It requires you to know the timing of your intake valve closing at @.050.
I made an Excel spreadsheet that will calculate your dynamic compression and your valve timing events based upon the duration of your cam @.050.
The real question is, what's an acceptable dynamic compression for different octane ratings? No one seems to know. I believe that stock VW engines had a dynamic compression of ~7:1.
My 1776, 9.1:1 static compression with a Web 218 camshaft at 5300ft altitude comes out around 7:1 dynamic compression. I run it on 91 octane gas.
John W. Kelly
I need some 80 proof.
