What size valves should I use
dawireman
Post by dawireman »
I am building a daily driver/ weekend fun at the track. I am debating on what size heads I should use. Any help would appreciated.
82mm Demello c/w crank
5.5 Demello rods
engle 120 cam
dual 44 webers
94mm p/c
straight cut cam gear
new (yes i'm going to try it) al case tapped and clearenced.
8.75 c/r
12.5 flywheel
Thunderbird header and exhaust
I guess that these are the specs you would need. It is going into my 66 beetle that i will use to commute about 120 miles per day. I don't really care about fuel economy but I don't want to have to look at the ass end of everybody in the slow lane like I do now in my 1600 stocker. What size valves would you recommed? Anyone?
Post by Marc »
As big as you can afford?
Seriously, the port work matters as least as much as the valve size, but 42x37.5 would be a good place to start IMO. A nicely done set of 40x36 heads would probably work as well overall, but with a 120 you must not be planning on too much stop-and-go work anyway, and you'd always be wondering what you missed out on...
superdrag73@work
Post by superdrag73@work »
I've always liked big valves. I like 44 by 38's for the street.
dawireman
Post by dawireman »
Don't the smaller valves give me more low/mid power? I am not really interested in speeds beyond 90mph or so on a dailey basis. Won"t the smaller heads run cooler? I am willing to pay the extra money for bigger valves if they will be beneficial to me on a daily basis. Also is the 120 web cam a good choice or should I look at the 125 or 130? I really don't want to run ratio rockers. I am most interested in 0-80 mph runs. I am running a stock tranny.
superdrag73@work
I had a 2110 with 44 by 38 valves, and a 130. With 9.3 to 1 on the street. I liked this combo a lot, but for a daily driver ,I think it's a bit much.
James2
Post by James2 »
I have 44X37 valves with HUGE ports on a little ol' 1914. It pulls from idle.
Buy the best heads you can afford. Go with at least a 42X37.5, with a "stage6" port job.
The cam will determine the power band more then the head size or carbs, exhaust, etc. They still need to work together.
here a proven combo, done by Hot VWs and repeated many times This is just the high lights-
94X82
K-8 cam( or web 86b)
Cb 044 heads 42X37 or 44 X 37. (Well ported, should flow over 190 cfm at 25 in on the intake)( CB CNC heads are a bargin)
1-5/8 merged header.
48 idf, DRLAs or IDAs. You want a 38-40mm vent.
CR 8.5-9.0.
Should kick out 160-180 hp, depending on the details and how well the heads are ported.
You will have excellent throttle response.
James2
Post by James2 »
Stick with 120 cam if you're not willing to run ratio rockers. I sure wouldn't run the 130. Any thing over a 125 just sucks for throttle response when compared to the smaller cams.
I would encourage you to run ratio rockers, the valve train will last longer and you can gain quite a bit of hp with the k-8 over the 120.
dawireman
Post by dawireman »
Ok I will stick with the 120 cam and get the 42x38 valves with a good p&p. I would go with the ratio rockers but this thing has already gone over budget by about 1400 bucks. I figure when I tear it down again at about 10k miles I may play with a different cam and or ratio rockers. Thanks for the help.
captCRUNCH
Post by captCRUNCH »
didn't i just see a set of heads on type 1 forsale? 42X37 already drilled for 94's? might wanna check 'em out.
