urethane bushings
urethane bushings
Has anyone put urethane bushings in a warrior front end beam this is my first time and they are being difficult.
urethane bushings
I did. I thought everone did! What else would you use?
urethane bushings
I want to use them they just don't want to fit the tubes. this is my first foray into to something like this I was told there are different size bushings which, i was not told about when i first bought these parts. So when i told a guy with a killer street bug the trouble i was having he told me about this site and said someone might have an idea what i might be doing wrong. I'm in the process of building a 63 baja bug from the ground up and i have all kinds of goodies to put on the bug. and will need some help now and then.
urethane bushings
Yes, the urethane bushings or sleeves are not one size fits all. Measure the ID of the beam and order what you need. BTW welcome to the world of specialty aftermarket parts. Ask lots of questions befor you buy and be prepared to ask more after!
urethane bushings
THANKS! will do!
Are there parts suppliers you can recommend with helpful people.
Thanks Again
Thanks Again
urethane bushings
Maybe I am a throw-back but I try mainly to deal with my local VW specialty shop. I know them, they know me and if there are problems with my order they take care of it.
- turboblue
urethane bushings
Baja44
Usually the aftermarket beams is DOM or chromoly tube and the VW sized bushings do not fit. They will have to be machined to fit. This is typical of the "warrior" or "extreme" beams advertised on most magazines.
urethane bushings
Thanks for letting me know about that.how would a machine shop go about cutting them to fit a lathe?
thanks for you're reply
Chris
Chris
- turboblue
urethane bushings
Chris
If it is not too much trouble, take the beam with you to the machine shop. Just have them take some dimensions and machine the bushings to fit. The vendor you purchased the beam from should have told you some "custom" work was necessary. Or should have been able to supply the correct bushings.
Gary
Gary
urethane bushings
You could do as Bugpack suggests and sand down the bushing until it fits. LOL, no joke, I had the same problem with the front end bushings in the stock tube so I called them and that was there suggestion. A quick trip to the belt sander to gently remove the excess material (probally left over from the mold)and they fit like a glove.
almost all aftermarket parts require some fiddling to fit, I'd be amazed if I bought a part that didn't need to be reworked somehow before installation.
Mike
69BajaBuggin'
Mike
69BajaBuggin'
urethane bushings
Thanks guy's with help like this it makes things alot easier to do.and more fun too!
Chris
Chris
