notching spring plates
can any one tell the maximun i can notch my spring plates . i have a 69 irs bug with double sping plates . thanks
1/2-3/4 of an inch is the norm for the bottom and some people notch the top around the upper stop but i prefer to remove the upper stop and clearance the cast iron instead of weakening the plate any more than required. Making a good radius on the notches and being carefull not to heat the plate while cutting it are also important for strength.
I have not seen it done an the dual plates before but i guess it could be.
If you look back through previous disscussions there are also a couple different ideas about how to increase travel. Notch the plate vs. remove the lower stop.
[This message has been edited by Hot Wheels (edited 01-27-2003).]
Don't If they are notched you will be running the CV at more angle then it was intended. Yes there is a small safty zone built into the CV but if the wishbone is bent only a little you will have CV problems. If you want more travel go to the T2 or Porsch CV. Yes some folks get away with notching there spring plates and some get away with dating there sister-in-law, but it's still risky & not a good idea. Vic.
On Bugasaurus (also a '69) I nothched/radiused the inner plate 9/16" and was able to run T1 CVs fine. When I put the 002 in, I went to T4/181 CV joints. No problems.
Aloha, Theo
http://groups.msn.com/BigIslandVWs/theo.msnw
Aloha, Theo
with the twins only the inner one sits on the bottom stop anyway ..
thanks for the replys . howed you know i dated my sister in law . so a 1/2 inch sould be ok with the type 1 cv . some day soo i hope to get a bus transaxel but for now im stuck with a stock unit .
thanks again guy as alway your great with the awnsers
