Is there asource for D-Jet MPC Harness boots
There used to be, but am having no luck.......i have resurrected a 412 and sure could use these.
- raygreenwood
There are several Ljet boots that work very well in this respect. Check around under the hood of some golf, jettas and foxes...mid to late 80's. Some of the air bypass valves and fan plugs have them. Ray
- Dave_Darling
I don't know if it's still the case, but in recent years Volvo dealers have carried the black ones. I have the part number around somewhere, but I can't find it right now.
Jeff Bowlsby uses different ones that hold onto the injectors better than the stockers; you might contact him to see if he'll let some go individually. http://members.rennlist.com/914_wiring_harnesses
--DD
--DD
I bought a set from Auto Atlanta a few years ago. They were pretty expensive. They came in Mercedes parts bags w/ MB part #s. If you need the #s I could probably look them up.
Mark
73 2.0 914
Mark
73 2.0 914
See what you can do it would be great.....
Here goes:
They all look identical to the boots on the 914 harness
Largest boot (6 pin)
Mercedes Benz part#: A 000 546 17 35
Second largest (4 pin)
Mercedes Benz part#: A 000 546 13 35
The two pin injector boot are not in a bag but there is a Bosch tag w/ them that has a part # on it. Same part # is inprinted on the boots:
Bosch part#: 1 280 703 012
I can send you photos off line if you need them.
Mark
73 2.0
[email protected]
Mark
73 2.0
[email protected]
- Dave_Darling
Hey, I dug through my archives and came up with some part numbers.
<I>The part number for the injector boot (Volvo) is somewhere in this mess of numbers, I read them all off to the parts guy and he got what he needed: 1st line - 943693, 2nd line - 2331, 3rd line - 31.
MPS/distributor trigger boot (Mercedes): 000.546.13.35.</I>
I hope that between this info and the Bosch part number above you get what you need.
--DD
--DD
Thanks guys
