Fan blades
John Massengale
Fan blades
I think i read somewhere that the cooling fan on a stock cooled type 4 engine can cool better by breaking off every 5th blade or something. is this true, or should I leave them all in? Thanks, John
TwoLiter
Fan blades
The fan is balanced at the factory, and breaking off blades will most likely throw it off balance. I don't think that is a good thing.
John Massengale
Fan blades
Yes yur right, my teacher says it probobly isn't a good idea either, But still don't know if makes it blow more air, John
johnhora
Fan blades
John...You've got too much time on your hands...no classes eh..
What you probably have heard was that some racers in the past have removed all blades except the main bolt points. This is done to reduce the fan drag on the engine. This was only done with an external oil cooler and usually some major ducting of air to the fan intake area.
Bottom line you don't want to do it. Especially on a street car....a constantly moving racer car was different.
And as above...the fan is balanced like a flywheel.
John
John
Fan blades
I sometimes remove evey other balade in the mill, and then rebalance the fan assembly to match..
Jake Raby
Raby's Aircooled Technology
www.aircooledtechnology.com
Jake Raby
- Dave_Darling
Fan blades
I have read that the stock fan becomes more inefficient at high RPMs, and that removing some of the fan blades regains some of that efficiency. But that it cools worse at lower RPMs, which is where a street car spends most of its life. (Well, except for Jake's cars--but he's a special case!
And the fan is always balanced afterwards, both on its own and then as a part of the rotating assembly of the engine.
--DD
)And the fan is always balanced afterwards, both on its own and then as a part of the rotating assembly of the engine.
--DD
John Massengale
Fan blades
Thanks, Guys, I will leave them the way they are, John
flat4-4now
Fan blades
my fan blade has 2 missing fins, both side by side. should i replace it or just have it balanced with everything else and go?
Is the t4 fan blade the same as the bus? and if so, what do new ones cost (PP=250.00)? I guess a decent used one would work...
[This message has been edited by flat4-4now (edited 01-25-2003).]
Zeke
Fan blades
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by flat4-4now:
<B>my fan blade has 2 missing fins, both side by side. should i replace it or just have it balanced with everything else and go?
[This message has been edited by flat4-4now (edited 01-25-2003).]</B><HR></BLOCKQUOTE>
I would look for another fan. Around here, they cost $20 used. If you know what you are doing, you can remove corresponding fins in a triangular pattern. I can tell you that in that respect, I don't know what I'm doing.
Milt
914 2.0-4 Race Car w/ 2.7-6 in waiting.
Milt
