our intentions for the car is track, strip and street. i know thts is a difficult thing to do. i figure if its fast on the track its fast on the street. and for the strip just deflate the rear tires a bit
basically, take a stock 914, make the rear portion stronger to hold more power, throw some fatty tires on it and install a j ported 13b 2 turbo intercooled rotary engine. then finish it off with suspension, brake and body upgrades.
weight will be the same as stock, only with 4-5 times more horsepower.
the engine is already done, tranny and front syspension of a 911 are sitting in the gurage.
all we really need help with is figuring out what exactly needs to be modified for more strength.
boxed trailing arms, welded up rear shock towers that have welded tubes going to plates of steel on the tranny mounts. solid motor mounts. rubber new tranny mounts. 930 cd joints.
we still need to send the tranny out to get the diff flipped.
what else could be done for more body strength?
why do you say the 915 tranny is no good? i thought it was able to handle more power and abuse?
