Tail to Side shifter conversion - firewall bracket
Moderator: Piledriver
Dave_Darling
Post by Dave_Darling » Mon Nov 25, 2002 5:05 pm
You don't need to relocate the hole--all you really need is a different-sized hole. Happily, there is a "converter bushing" that has the OD of the early hole and the ID of the late front shift rod.
As for a lip to hook the boot onto, you'll have to figure that one out for yourself. A lot of people who convert cars just do without hooking the boot up--it does tend to push against the firewall because of its accordion shape, but it certainly isn't sealed...
--DD
vwduud
Post by vwduud » Mon Nov 25, 2002 7:23 pm
Great news. Thanks Dave. Is there anything else I would need for the swap, besides any worn parts I find from the donor (seals, synchros, standard shift bushings etc.)? In other words, besides the converter bushing, are there any other "conversion" parts that I will have to buy?
vwduud
Post by vwduud » Tue Nov 26, 2002 2:41 am
After speaking with John Hora about this conversion, he brought up something I was unaware of. He explained that the hole in the firewall, where the shifter exits, needs relocating, as well as having a different type of mounting lip for the enclosing bellows. We talked of using a side shift donor cars firewall (just the shifter area section), as well as, someone making a bracket, for this conversation. Does anyone know who manufactures/supplies this bracket? I have a donor car, but would like to fully understand my options before I break out the cutting tools. Thanks - Jim
Dave_Darling
Post by Dave_Darling » Tue Nov 26, 2002 12:44 pm
No other "special" parts to buy, but....
You need all of the shift linkage from the later car, from gear shift lever all the way back to the tranny. If you really like your old shift knob, you can keep that. You need the tranny. (Or at least the shift rails and such.) You also need the late motor mount bar, with the solid mounts for the outer end and the rubber mounts for the middle. And the brackets that hold those mounts onto the engine case.
--DD
van914
Post by van914 » Tue Nov 26, 2002 12:45 pm
If you need an engine mount bar let me know. I have one for cheep but shipping is costly it weighs a few pounds.
r_towle
Post by r_towle » Tue Nov 26, 2002 4:51 pm
BTDT,
The out mounts, where the bar is fastened to the "frame" of the car are solid, basically washers.
Where the bar mounts to the engine there a rubber ones, buy new ones.
Where the rubbers mount to the engine there is a special bracket behind the fan housing, you MUST get this off the donor, I paid dearly for this part.
The rear muffler bracket is a must have.
The shifter rod
The front shifter rod
The shifter
All the bolts.
While your at it replace the clutch cable etc... The pulley might be worn.
The bushings are all available at Pelican parts, I made custom bronze ones that made the shifting even better, another story...
I did the flywheel and a whole new clutch,
Oh, the clutch release fork has a bushing, replace it.
Rich
Dave_Darling
Post by Dave_Darling » Tue Nov 26, 2002 5:16 pm
Uhhh, the muffler bracket shouldn't need to be changed. You change it when you swap from 1.7 heat exchangers to 2.0, or from the 75-76 exchangers to either of the early ones, but not when changing trannies....
--DD
r_towle
Post by r_towle » Tue Nov 26, 2002 5:52 pm
ok
i must have a spare in that pile of parts then.....
vwduud
Post by vwduud » Wed Nov 27, 2002 2:19 am
Thanks. I will be stripping the donor car this weekend. I imagine, since the motor and tranny are still intact, most of these parts should be present. As far as the motor mounts, on the motor mount bar, do the inner, outer, or both deteriorate typically, requiring replacement? Just trying to get my shopping list together. - Jim
