914 or Type 4 heads
CA. 73 1.7
914 or Type 4 heads
Post by CA. 73 1.7 »
Does anybody make performance heads that bolt up to a 914 or type 4 and its factory exhaust? As opposed to a Scat(or whatever other manufacturer) Type 1 where you have to use bug type headers.
Bleyseng
914 or Type 4 heads
Post by Bleyseng »
Porsche did a nice job with the 914 2.0l heads, just try to find a nice set!
76 914 2.0L
914 or Type 4 heads
Post by MASSIVE TYPE IV »
The 2.0 heads are weak in the spark plug and exhaust port areas...with mods they work and flow like mad.
Forget the aftermarket castings, Scat and the others are made for power not cooling, VW all the way for me.
Jake Raby
Raby's Aircooled Technology
www.aircooledtechnology.com
CA. 73 1.7
914 or Type 4 heads
Yes porsche did do a great job on the 2.0 heads. These heads also have a porsche price tag. I have a 1.7 with 1.8 high compression pistons and i was just curious if there is an aftermarket "TYPE 4" head. I have never come across one. I have seen and read about hundreds of type 1 heads but no type 4. I guess that the aftermarket dosent like our exhaust ports. Ps does anybody know a GOOD person wor head work in Southern California. Huntington Beach, Orange county would be nice?
Thank you all for your comments
Dave_Darling
914 or Type 4 heads
Post by Dave_Darling »
The only aftermarket heads I know of are the ones with the Type I exhaust ports. Hopefully that will be changing at some point, but....
As for shops, Otto's is a good shop if you can deal with Otto's personality. Some folks really like the way he is, some don't.
--DD
CA 1.7 914
914 or Type 4 heads
Post by CA 1.7 914 »
What about "square port remmele heads"? Crimson axe in the type 4rum mentioned this on a post about chris' new headers. Does anybody know the Remmele address? or have info on these heads?
Racer Chris
914 or Type 4 heads
Post by Racer Chris »
The Remelle square port replacement heads are imported by John at www.aircooled.net. They come in several performance levels. I have seen a Level 4 head, and it was very, very nice (48x38 valves). I am making stub pipes for these heads to adapt my performance exhaust systems. The heads can now be used on a 914 engine for a high performance application.
Chris F.
www.tangerineracing.com
Ryan72
914 or Type 4 heads
Post by Ryan72 »
If you are concerned about the price of the porsche 2L heads there will be no need to even enquire about the remeles, they are some of the most expensive you can buy. As far as good reputable head work goes in orange county area, A.J. Simms or Jeff Denham are your best bets, some people have long wait times with Jeff heads, I have delt with him and service has always been prompt when I make it clear that I have a deadline, thats just my opinion, Take it or leave it, but both are very local.
JohnConnolly
914 or Type 4 heads
Post by JohnConnolly »
Ryan,
except there are 2 TYPES of Remmele heads! The "Remmele" heads are the big dawg $3300/pair heads, but the "replacement style" Remmele heads are actually less $ then 2.0L 914 heads, AND flow much better too!
So the heads used on Crimson Axe's engine (for example) are well in the range of "affordable" for the average Joe, while the EXPENSIVE ones may not be.
Like I said in another thread, the L4 Remmele replacement heads basically obsolete expensively reworked 2.0L 914 heads AFAIAC.
John
Aircooled.Net Inc.
Bob Martinez
914 or Type 4 heads
Post by Bob Martinez »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Dave_Darling:
<B>
--DD
</B><HR></BLOCKQUOTE>
Dave,
No offense towards you, BTDT (no public comment), spend your money wisely, you may try FAT Performance in Orange/Tustin or Mr. Tuttle in L.A...no attitude and they both did excellent work on mine...
Good Luck
[This message has been edited by Bob Martinez (edited 08-07-2002).]
914 or Type 4 heads
The "replacement" Remelles are AMC castings with big valves, etc. The castings look nice, and the intake ports IDs seem noticably bigger than the VW heads as cast, a little porting would probably do wonders, as there is plenty of meat.
The AMC/stock heads are ~$350 ea IIRC (retail/walk in), perhaps they do 914 valve sizes???
Worth asking.
(couldn't find out jack about them online other than here)
AMC also does heads for other "troublesome" motors like for 3000GTs that lose seats or crack from the factory.
(I understand that is their claim to fame)
I just wanted new heads that didn't suck.
The only issue I had (stock 2.0 VW replacements) was having to spend and hour with various tools on the valve covers so they didn't leak.
Jake said something about having the valve cover area redone flat or thinner.
They are available in oval or square exhaust versions.
Do the AMC heads have decent rocker studs?
[This message has been edited by Piledriver (edited 08-10-2002).]
Guest
914 or Type 4 heads
Post by Guest »
Their rocker studs suck..
Redo every machined surface, including registers and the valve cover deck..I have seen them .020 out on my mill, with a freshly indicated head.
Kathy Jacobs
SEVWC / VW Trends
914 or Type 4 heads
Thats my post above....Kathy logged in from my computer earlier aand I did not notice it...LOL
Jake Raby
