Audi S3 225 bhp motor Mid mounted
- Bobtail
I am building a '63 bug and mounting 1.8T motor in the middle,anyone done similar? any info on chassis and suspension details will be welcome.
Michael Ghia
I would expect that it would easier to do this with either a tube chassis with wishbone suspension or just cutting off the gearbox forks and adding a space fram again with wishbone suspension. Sounds good, give us all a pic of it as you get on.
Mike Ghia
Modification is a form of Art.
Mike Ghia
Rmcelroy
After purchasing a 914 motor/trans for a Beetle, I had the strange notion it might be easier to mount the Beetle body to a 914 pan instead. Is it just me or what.
Regie
Regie
PurpleBug
If you take a look in the December 2000 issue of VolksWorld magazine you will see a guy that put a Super bug's body on a 914 pan thus keeping the 914 suspension, brakes etc. appart from the engine which he removed to install a unit from an 1973 Carrera RS. Thats 2.7 litres of power, 210 bhp. Now thats what i call a conversion. That bug has the engine mid mounted which means no rear seats and two empty compartments, yes! no engine in the front or the rear!. Its right behind the driver boxed and sound proofed.
- Bobtail
The major headache with that conversion is the 914 has a longer wheelbase and you end up with iffy looking wings at the rear.
I've just finished a days work on the project we have decided to use S3 front suspension on the rear.So I've got a starting point for the rear engine and suspension carriers,the main carriers hade from 2" tube.
The floor pan has been stripped of the floor panels and the mounting rail is now 30mm box.
I will try to post some progress pics as I go.
74Super
Bobtail,
I just tried to access your homepage, and I have also tried in the past to no avail. All I ever get is a series of "FortuneCity" graphics...for everything. All the backgrounds, graphic links, and text links all are the same FortuneCity graphic, and no matter what link I use I just get more of them...I won't even go into the multiple "pop-up ads," but at least they aren't more FortuneCity graphics, it was very frustrating.
Has anyone ever mentioned having problems to you before? Maybe there is an error in some Java code? I'm stumped.
Anyone else have this problem?
Doug
BTW. I'm using PIII/550 with 224 RAM running MSIE 5.5.
**Don't forget to remove "spam" to send me mail**
[This message has been edited by 74Super (edited 07-04-2001).]
Doug
- Steve C
Hi
A local Porsche tuner is thinking of using the rear suspension out of Boxster on a 914, its a modular setup and the parts are reasonable by Porsche standards.
Regards Steve C
Regards Steve C
- Bobtail
I'm using the company website lately which is www.centralvwaudi.com
you could try my original site http://website.lineone.net/~cooperp55
and thanks for the info guys.
- Bobtail
Some more work going on today, recent work on site projects.Golf A2 front suspension measured up today and it looks like the one to fit>
- Bobtail
I've now put up a projects page on www.centralvwaudi.com which has pics posted during the build.plus some other interesting projects!
- 69bajakid
Im thinking of mounting a 1.8T in the rear of my baja bug..who makes a kit to adapt it to an 002 bus tranny?
also..do these motors make good low end power?
thanx
Cale
"Its not how big you build it, Its how you build it big"
thanx
Cale
- Bobtail
I have just put the body back on and calculations seem to be confirmed and it fits where it should!
I need to measure up the total track F&R to make a guess at what width wings to get.
Any suppliers or contacts would be appreciated.
Thanks Paul
Thanks Paul
- Bobtail
Well The calculations seem to work the rear track puts the wheels 60 mm further out so Remelle will be supplying those nice wings.
the front track with wheel fitted is about stock dimension so we'll get 40mm oversize for the front.
I just got a good digi cam so the site pics will be viewable I.E not join the dots
- Bobtail
Decided to use AVO adjustable shocks which are on order, as are the remelle wings.Its just a question of waiting for them to arrive.Guess I've got more time to post up some more pics then!!
Brutus
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by 69bajakid:
<B>Im thinking of mounting a 1.8T in the rear of my baja bug..who makes a kit to adapt it to an 002 bus tranny?
thanx
Cale
</B><HR></BLOCKQUOTE>
KEP does I believe.
Yep.... real good low end for a turbo, probably one of the smoothest boost transitions I've driven.
Hey Bobtail.... gotta know, how you gonna hook up the shifter? I've thought of doing simular on a street buggy (only with A2 stuff), but it's never gone any further than thinking...
thanx
Cale
KEP does I believe.
