Water cooled heads
mharney
Water cooled heads
This is mostly a conversion topic, I guess, so I am posting it here.
I've done some searching around about water cooled heads for a Type I and got a little information, but I am really pretty unclear on it.
Here's what I am thinking about - it's obvious that it's hard to get continuous high horsepower out of a Type I engine, and consequently the require high fan speeds (stock pulley ratios) and a lower geared transmission to keep the load down, or things get hotter. I understand that some years back people were doing water cooled head conversions, and wonder about the feasibility of bringing the concept back into play, since technology is capable of much more (look at all the products that are out there now that were not, say, 20 years ago.
What made people stop trying it? Was it not a solid solution?
Additionally, can anyone give me details or point me in a direction on doing it? I understand certain waterboxer heads were candidates, but know nothing about which, and what bolt pattern issues exist, and performance considerations.
I realize there are some hurdles in terms of radiator and pump/thermostat/plumbing, but feel confident that those are small issues that I can work out. I just don't know what people were using to do this, and if anyone is even doing it anymore.
I do not want a full water cooled solution.. just heads. Thanks guys.
My VW Page
My VW Page
mharney
goatmaster187
Water cooled heads
I believe that the bore spacing and stud pattern is the same on t-I heads as on the waterboxer ones. You could probably bolt em on and run a water pump off the crank pulley. You'd have to build a bracket to mount the pump to. There might be a little trouble getting the cylinders to seal to the head, but a little bit of milling could take care of that.
goatmaster187
Water cooled heads
Ok so I went back and looked at the head designs side by side and they are not the same, but pretty close. There are a few problems to be resolved but nothing too complicated. The holes in the case need to be drilled off center and inserts or some sort of plug need to be added. The water jackets on the case side of the head need to welded up. And a few fins may need to be clearanced on the cylinders. I haven't figured out how the air cooling portion of the engine will be kept. There may be some real clearance problems on that.
mharney
Water cooled heads
I have too much invested in my engine to fiddle with these on it. I'll have to wait until I get together some parts for experimenting. I'm not interested in relocating studs in my brand new case, and don't want to de-fin any part of my birals.
Thanks much for the information- I will give it a shot on the next build, which will be a 1914.
Thanks guys!
My VW Page
Thanks much for the information- I will give it a shot on the next build, which will be a 1914.Thanks guys!
My VW Page
TIMBERWOLF
Water cooled heads
Unfortunately the bore stud spacings are NOT the same as either type one or four. Do a search on 'OXYBOXER' this gives info on this matter and some solutions. One guy in the UK put Scooby heads on a type I, blew it and got 500hp, and no it wasn't easy!!!
- Bobtail
Water cooled heads
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by TIMBERWOLF:
Unfortunately the bore stud spacings are NOT the same as either type one or four. Do a search on 'OXYBOXER' this gives info on this matter and some solutions. One guy in the UK put Scooby heads on a type I, blew it and got 500hp, and no it wasn't easy!!!<HR></BLOCKQUOTE>
Who was that ?
www.centralvwaudi.com
Who was that ?
Paul_S
Water cooled heads
My father saw some water cooled heads for a Beetle a couple of years back at a local Beetle shop.
They were built for Beetle racing and cost about $ 1800 per head.
$3600 just for heads is a bit much for my pocket.
Unfortunately I don't have any useful info on the heads.
Paul
Paul
goatmaster187
Water cooled heads
I have access to some junk cases and water-cooled heads. If I get a few projects out of the way I'll tackle this one. I'll get all the critical dimensions and such and post em. I'm pretty sure that it can be done for less than a couple grand.
TIMBERWOLF
Water cooled heads
Can't remember his name just now, he ran it 4WD in UK autocross, kind of tarmac and gravel circuit racing. Bobtail posted some time back about him selling it. Maybe do a search.
- Bobtail
Water cooled heads
Of course Peter Harrold!!
Thats still for sale aswell
