for those thinking of midengine...
vwfye
Post by vwfye »
after living in the mid engine world for a few years, here are some things i have found good and bad.
good-- handling is only limited by the ability of the tires! wheel hop isn't an issue. hydraulic clutch makes even a stiff clutch easy to deal with.
bad-- there is nothing 'off the shelf ready' when you break something. and, don't buy a cable shifter for the car!!! they are sloppy and hard on the nose cone. get a replacement nose cone unit from Jamar or Prowler's!
well, i hope this little diatribe helps.
konzept 396 w/2332cc of fun
cj011
Post by cj011 »
is there any hydraulic clutches that bolt up to a vw type tranny, without mods
danielzink
Post by danielzink »
SACO hydraulic clutch:
http://www.vwispwest.com/specials-ga321000.htm
Dan
[email protected]
http://users.aol.com/my65notch/index.htm
[This message has been edited by [email protected] (edited 06-12-2002).]
cj011
Post by cj011 »
thanks
ericsbracer
Post by ericsbracer »
Now here is a real mid-motor VW... http://silverstone.fortunecity.com/merc ... p/fc12.htm
Eric Plum Bug Racer
TEAM SBO! Motorsports
Prancing Basset V.A.R.
www.superbeetlesonly.com
wizrod
Post by wizrod »
Thanks for posting the pic of the Fitti-VW!! I've been looking for info on this car for ages. Have you got any more details?
Paul Image
www.wizrod.com
ericsbracer
I wish I did - I found that by searching through Google... I know there was an article published in late 69 or early 70, 1 or 2 pages I think - at least 2 of those pics. I'm not sure what Mag it was, though...
Eric Plum Bug Racer
Steve C
Post by Steve C »
Hi
There are some interesting almost mid engine chassis here http://nova-international.net/data/chassis.htm
Steve C
staab
Post by staab »
that is one of the ugliest bugs ive ever seen
Michael Ghia
Post by Michael Ghia »
You can use a T25 transmission for it's hydraulic clutch... the bellhousing is the same as the T2 bellhousing... just with different parts bolted to it.
I'm using Porsche parts for mid-mounting. The 915 box can be converted to a 916 trans as was used in the Porsche 916. This is a side shift mechanism and rod.
I do have the problem of getting air to the engine though. I'll start off with NACA ducts in the rear 1/4 windows.
MG
Modification is a form of Art.
"that is one of the ugliest bugs ive ever seen"
I couldn't agree more, but a mid engined 3.8 litre flat 8 (2x1600) in a bug body probably was pretty darn quick...
vwfye
Post by vwfye »
hey mike ghia, i just rerouted air to my midengine from under the car using 10cm aluminumn flexy hose. it dropped my oil temps dramatically and best of all you can't see the ducting unless you....well, duck!
ericsbracer
Ugly? Well - beauty is in the eyes of the beholder... Fast - You Bet!! Out qualified a Ford GT40 and a Lola-Chevy!! Image
Eric Plum Bug Racer
bugboy
Post by bugboy »
to put in a vw engine in the middle would you just turn it backwards like they do some of the sand rails. i have never seen this done bfore and how would you shift.
Type 396
Post by Type 396 »
bugboy,
you have just have to flip the ring and pinion in the stocker tranny and turn the whole thing around... I love mine! shifting is done with a VW midengine unit and hydraulic clutch.
