I want to put a waterboxer engine in a Squareback but want it to fit below the stock engine cover. Anyone know if this will fit? If so will it bolt up to the stock tranny or will I need a adapter? The big thing is will it fit in the stock engine compartment! The Suby engine won't fit under the lid, so I am not sure if anything else will fit.
Richard
Lost in Texas with Bluebonnets and Bluebell Icecream
Type 3 Waterboxer Conversion
- Steve C
Hi
I received a really nice email from a fellow who has fitted one to a fastback, you can see it here http://www.tangen.nu/volkswagenpage.html
Steve C
Steve C
- fastback
The WaterBoxer(or WasserBOxer as i call it) Will fit under the original Engine Cover.However i have installed this engine in my -69 Fastback (check out the link above/below)and i wanted as much ground clearance as possible so i had to modify the engine cover a little bit.(the original Exaust also fit's nicer)I had to build it up som places with about 1".The engine fit's straight on your Transmission if you use a Type 4 210 or 215 mm Flywheel.If you use the Original 228 mm Flywheel you have to remove some aluminium inside the Transmission/Clutch housing due to the larger Pressureplate.
You also have to fit an needle bearing to support the main axle from the gear box(this is a MUST even when converting to a regular Type 4 Engine).
And you hve to use a late Gearbox with support for the Release bearing(or add the support mechanism to an old one).
You also need a starter from an automatic Transmission(Type 1 or 3), which is supported in both ends.
If you have late Suspension(IRS -68 an newer) you have to modify rear engine mounts(This modification lets you adjust the engine to fit under the engine cover or not)
My VWebSite
My VWebSite
PapaG
Hey guys thanks for the Info. I have about some time to get it ready to go to the Type 3 Invasaion 2002 in Parma Idaho.. The wife wants ac and heat. Any one else jump in too. Now starts the quest for 2.1 W-boxer engine and electronics...
Jorn I didn't see any air inlets for a radiator? I guess it is in the spare tire well.
[This message has been edited by PapaG (edited 09-20-2001).]
PapaG
Ok I see it. Bright refelections from the paint and chrome. Your "English" is better than a lot of us.
. Screen or net would be right I think. I saw a squareback with what looked like the grill opening from a new beetle installed in that location. I never thought about the lovers from a T1, but thought a superbeetle front pan with the holes could be made to work.. If its not too much trouble you could email some pictures too.
Richard Green
[email protected]
NOTE: I fixed my email address here. Cant spell my own name.
Richard
[This message has been edited by PapaG (edited 09-21-2001).]
. Screen or net would be right I think. I saw a squareback with what looked like the grill opening from a new beetle installed in that location. I never thought about the lovers from a T1, but thought a superbeetle front pan with the holes could be made to work.. If its not too much trouble you could email some pictures too. Thanks
Richard Green
[email protected]
Richard
- fastback
PapaG:
I have cut out a large hole in the front plate under the front bumper and have welded in a louvered "plate" (welded in where the License plate used to be.cut out from a T1 engine lid.take a look at the first picture... You can barely see it....
I have covered the hole with "Netting"??(is this a English word??? I'm from Norway so my enlglish is'nt complete...heheh)
If you're interested in more pictures i can E-mail you some...I have'nt put them on my WEBsite yet.
My VWebSite
My VWebSite
liberty
would it be easer if you went with carbs on this conversion?
i already have an upright motor in my notch right now. and i have an end less supply of vanagons and parts for them.
i even have a zero mile waterboxer siting here ive been wanting to use. so fitting them under the cover isnt an issue.
