What would be involved in runing a mild 1776cc on airplane fule? any carb changes or timing? or can it even be done?
sorry if ist a dumb question. i was just woundering
Ariplane Fuel
NormanW
Ariplane Fuel
The first thing is getting it in the car as most airports will not let you do it at there facilities. It is possible to get it but you will have to run it at the track only. The Goverment frowns on it being used on the roads. Its a taxes thing.
ShaneW
Ariplane Fuel
Airplane fuel is pretty low quality with a lot of tax on it. Do some searches in Google and see for your self. I know a couple of pilots who use car gas because it burns better and is a whole lot cheaper.
ShaneW
ShaneW
Ariplane Fuel
The octane numbers on AvGas look impressive but they use a different testing method - airplane engines are low specific-output, low-compression engines and run at a fairly low constant speed as a rule (all characteristics shared with a STOCK ACVW engine, but you probably didn't have a stocker in mind, huh? They do still put 2% lead in the 100LL fuel, which is illegal for street use these days. You can play with mixing it with automotive fuel or race gas, but it really isn't worth the trouble in my experience. You might find this interesting:
http://www.vtr.org/maintain/gasoline-octane.html
ellectron
Ariplane Fuel
thanks for the info guys.
i know a few people that run there Camaros
on Avgas. in my small town it is easy to get. i went with my budy to fill up. just drive 2 miles to the airport and drive right up to the pump. the guy working there said "that sure is a weird looking plane". then started to fill us up.
but i'm sure there is some type of law for doing that esp here in California.
Ariplane Fuel
running any different viscosity fuel will change tuning , both timing and jetting.
Avgas, has lubricant properties, and is made for low chamber pressures, as aircraft turn 25-3500 RPM max, else their props explode...No engine revving, no acceleration, or deceleration for hours at a time...Not a wise choice for a car.
ellectron
Ariplane Fuel
thats interesting info. it seams to work well in th camero though. he has a 350 with a 750cfm carb. noth else special. but it sure suprises me with the power. it can break traction at 50mph. looking to keep up with him in the old v-dub.
- Lo Cash John
Ariplane Fuel
Perhaps your friend should do some back to back tests at the drag strip. Make a couple of passes on avgas then drain the tank and make a couple on pump gas. Then to really make him mad try it on some real race gas (Cam2, Powermist, etc). He'll probably see very little change in et/speeds as his car doesn't have a knock sensor, EFI, or any other means of knowing what octane it's burning or how to take advantage of it. And as you said it's just got a big carb and nothing else special, i.e. factory compression, valve, chambers, ignition etc.
On the positive side, with all the money he saves by running pump gas from now on he'll quickly be able to buy some go fast goodies.
[This message has been edited by Lo Cash John (edited 09-15-2002).]
- BoostedBug
Ariplane Fuel
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by ShaneW:
<B> I know a couple of pilots who use car gas because it burns better and is a whole lot cheaper.
ShaneW</B><HR></BLOCKQUOTE>
Man are they crazy! Avgas has a special anti-freezing agent in it that keeps the fuel from freezing at high altitude. Am I right on this Jake?
Steve
65 2332 Turbo Street Ride "I hope"
www.air2water.org
Steve
www.air2water.org
- vw505
Ariplane Fuel
yes you are thay add some stuff called (priss) we dont you it on are birds it causes flame outs on t700 turbo shaft jet engines . cam2 is the way to go . i use it on my race motor and it has 13to1 comp.
