Anodized Aluminum Engine
- jasonb
Has anyone ever thought about having one of the new aluminum engine cases anodized?
Anodizing aluminum actually lowers it's thermal resistance, which causes it to shed heat quicker. Also, anodizing does not distort the metal and can be applied with a top thickness as little as .0002" for hard wearing applications.
Most importantly, it would look really cool.
scottk
What about ceramic coating one??
kdanie
Ceramic coating would hold the heat in. Contact MicroCoat at http://www.sonic.net/~sc7500/ . Bruce Corrento can hook you up with a high tech coating that NASCAR racers use on their brakes to shead heat.
ken
ken
- jasonb
Cost might be the issue here. Anodizing is relatively inexpensive. I envisioned the cost at about $100-150 for the case. I don't know for sure though. Does anyone have any experience with prices for anodizing stuff.
5nine
it would look bitchin !!
Dexter
And you can Anodiza At Home!, That's right, folks! Anodization at home is now a possibility! As long as you have a Vat, I mean Pot, large enough to handle half an engine case, You too can anodize aluminum at home!
Anodizing at Home
Based on the number of companies selling, and people looking for, anodizing services for aluminum parts, I wanted to provide this info to the R/C community. Often anodizing is considered and/or presented as a difficult and expensive procedure. As it turns out, it really isn't that hard or that pricey.
Supplies Needed:
The first thing to do is to get the following things together: First on the list is the most expensive item: a 6 to 12 volt battery charger. They run from $45.00 to $110.00 depending on model, functions, etc. While it may seem like a lot, it does have other uses. (You could charge a battery, for example.) =) The next item, though not that expensive, will take some effort to find: battery electrolyte, a.k.a. sulfuric acid. This should be available at a battery wholesaler for about $2.00/gal. To make the negative ground, you will need some aluminum ground wire and aluminum-foil. The wire can be found at an electronics store for about $35/spool, and you should have the foil in the kitchen. If you happen to be out of foil, you can pick up some more at the store when you go to buy the last item for this project.
No super-special chemicals or solutions necessary to make the colors; just plain-old fabric dye. (Something like Rit dye, for about $5.00.) Rit offers something like 30-40 different colors, so you have quite a number of choices for what color you want your parts to be. An optional item is nitric acid: about $25.00/2.5 L. (This is used to clean parts prior to anodizing, but there are some cheaper alternatives. See end notes.) This is available at chemical supply stores. Should you not be able to find any, you can try to get on the good side of the high school science teacher. He may help you out since you only need a few ounces.
Safety Precautions:
There are a few precautions I want to go over to help keep you from blowing up the house or trashing the garage. First of all, do not mix or store your anodizing solution in a glass container. Something could happen to make it break, and most households are not equipped to deal with that kind of spill. You also don't want to knock over the container, so a stable, rubber bucket makes a good choice. You will also need to be certain that the part you want to color will fit in the container without sticking out of the solution, and without touching the negative ground in the bottom of the container. Any acid that you don't use, keep in what it came in, or an old plastic bottle, like a bleach bottle. You can also store your used solution this way for doing more parts later.
(Make sure that there is absolutely no bleach left in the bottle. Acid and bleach make chlorine gas. Very bad. Don't breath. Poisonous.) Safety also applies to the nitric acid, but in a different way.
It is imperative that you label and keep track of this stuff, as it is a stronger acid than sulfuric, and more dangerous. The breakage/spill problem is not as likely since you won't have that much around. (Unless you bought more than a few ounces from the chem store.) The last note about the acids is to mix properly when adding acid and water. Always pour acid into water, never the other way, and do so slowly, being sure to mix in well. There is a reaction taking place and it releases a lot of energy. During the anodizing process, you will be running electricity through a weak acid solution. This creates hydrogen (just like charging a battery) which is very flammable.
This stuff burns at the speed of thought when ignited, so do be careful. (Read as Remember the Hindenburg?) Make certain that there is some way to ventilate the project area, and DO NOT let any sources of ignition near the project area. Other precautions you should take include safety glasses, rubber gloves, and maybe some sort of drop sheet under the area.
(Editor's Note: I also recommend not using a glass container, I highly recommend use of glass within a plastic container to help keep the acid from eating through plastic, but keeping the glass less breakable in the event the container falls over.)
Preparations:
One of the most essential things you need to do in order to get even color over the whole part is to be sure that the part is absolutely clean. You want it free of all contaminates, from dirt to the oils in your skin. This is where the nitric acid and some rubber gloves will help. A solution of 1-2 ounces of nitric acid in a gallon of distilled water will allow you to clean the surface in preparation for the anodizing. Aluminum oxidizes very quickly when exposed to air, so the easiest way to keep it clean is to clean it just before you are ready to start working on the piece. (You should rinse the part with distilled water before you put it in the next acid solution.)
Other options are carburetor or brakes cleaners, or other similar degreasers. Soap and water will work also, or cleaners like Simple Green. These are cheaper, a nitric acid wash is the best. (You decide, it's your money.) Make your negative ground with the aluminum wire and foil. Shape the end of the wire into a paddle shape and cover the round part with the foil. What you want to do is create a flat, round shape to sit on the bottom of the bucket, with a lead that comes up out of the bucket. You will clip the battery charger's negative lead to the wire that comes out of the bucket. When you are ready to start, you will want to mix up your immersion solution. In your rubber bucket, combine the sulfuric acid and water to come up with a solution that is about 30% water. (1 part water to 2 parts acid.)
Place the paddle in the bucket and attach the negative lead. Then attach the positive lead to the part, making it an anode, and immerse it in the solution. (Remember that the two leads the paddle (cathode), and the part (anode) should not touch.) This is the best time to turn on the charger: once the part begins to fizz, leave it in there for about 10-15 minutes. After about this time the part should no longer conduct electricity. (You can also use an ohmmeter to check conductivity, but this is not needed.)
Turn off and disconnect everything, and rinse the part in cold water. Don't use hot water! You will find out why in the next section.
A couple of notes:
It may take some trial. It wouldn't be a bad idea to get some scrap aluminum and play with it before you start anodizing your Wanted parts. You can check out the above, as well as pick the colors you like best. If you test out some colors, you will also learn just how long or short you need to work with the color solution.
Color:
So now it doesn't conduct electricity, and is ready for color. It's been rinsed and waits eagerly to change to a new look. Don't wait too long to do the color, due to that oxidizing thing again. You want to mix up a strong solution of dye and water, in a container that can be heated. The solution needs to be at low heat, such as on the stove, so bread and cake pans work well. Again, you need something that will fit the whole part, but it's okay if it touches the bottom this time. I would recommend turning parts every few minutes just to make sure that you get all-over color. Inform your mom or wife that the pan can (and will be) washed out. It is important that the heat be low enough. If the solution gets too hot, you will seal the surface, and it will no longer take any color. (See, told you to rinse it in cold water!) Leave it in the dye until the part is slightly darker than you want it. The next step is to seal the surface of the metal in clean, boiling water. This will leech a bit of color from it, thus the slightly darker color in the previous step.
End Notes:
It is important to realize that the process described above will yield only one color on your part. At this time, I haven't found out how to do any of the splash type of anodizing. Also, this process is for aluminum. I don't know how, or if, it will work on other metals. (I doubt it.) Anodizing only works well on rock metal like bar or sheet stock, as opposed to castings. If it was forged or machined, it should have the density to take color through this process. I figure this shouldn't be too big a problem with many r/c parts, but just thought I should let you know about it.
Something to consider when looking for a charger, are how many amperes it puts out. Without getting into any mumbo-jumbo, anodizing relies on 10 to 40 amperes per square foot. For small brackets and such, this is no problem. The larger parts however, may need the higher levels of amperes. The other note about part size, has to do with how long you leave it in the solution. Above it said 10-15 minutes, but that is for a smaller part. The larger parts may not only need higher amperes, but more time as well. I would recommend an ohmmeter, but again, I have one already.
So there you have it. Quick, fairly easy, and not too expensive. If you don't have the charger, then your first anodizing session could cost a lot. But, then you can do it again for much less. Or do your buddies stuff. Or talk them into chipping in on a setup for all of you to use. We all know ways to help make things cheaper.
And the stupid statement required to cover myself... If you try this and something gets messed up, or someone gets hurt, you are on your own. Deal with it, you can't blame it on anyone else.
Anodizing at Home
Supplies Needed:
Safety Precautions:
Preparations:
A couple of notes:
Color:
End Notes:
- jasonb
Thanks for the great information.
I'm left with this one issue: Your instructions say that cast items don't anodize well but the information also leaves me wondering if this is only true for non heat-treated parts.
Any idea how well the heat-treated, cast heads and engine case will take to anodizing and coloring?
- Lavabo
Are you sure its a good idea to anodized a complete type4 engine case ?
Wont that process add a thin layer an can interfere with sealing surface when joining the case or even with all the internal part ??
- jasonb
I was thinking of the new aluminum Type 1 cases.
Either way, a professional can control the thickness of the surface coating and it can be limited to anywhere from .0001"-.0004". If there are any surfaces where the tolerances are tighter than that, then the areas could be masked so that they receive no anodizing. I don't know how this masking is achieved but I could make a few guesses.
Dexter
As you might have noticed, that article refers to R/C and related equipment.You could definetly mask the entire interior of the case by using some plastic(plexiglas cut to the right shape and adhesive gasketed on) but i think you prolly ought to leave the anodizing of important stuff to the pros- i don't know aboot the diff betwixt anodizing castings and forgings or stock, so hopefully there's someone here i can defer to.
Tom Simon
Dexter, great post! I think you about covered it. I have a few things to add that popped into my head while reading your fine post.
Anodizing is a messy and smelly process... do it in your garage and the neighbors might think you're cooking meth or something. Yikes!
Stock VW cases have magnesium in them, enough that you can get the chips to 'light' if you try. I'm not sure how well it will take color, or if you can anodize mag (but I don't think you can).
The process doesn't work well with glass bead blasted or heavily sanded parts for some reason. Maye the silica gets imbedded in the surface, causing poor conductivity or something?
Anodizing prices vary a lot. In the SF bay area, where I live and work, it can get pricey for one piece. Nevada doesn't have the same air quality controls, and can be a lot cheaper. In production, someone could probably anodize a case for $50 each. I would definately give the platers an old 40hp case to play with first.
Tom Simon
I just went back and re-read the original post... Doh! new Aluminum case, got it. I think they are rough, sand cast. Generally "as cast" surfaces don't come out that good, but you could try. Machined surfaces anodize real good. Exstruded stuff comes out good. Welded parts can have a color variation if the weld rod wasn't the same chemical makeup as the base metal. Can look grey out into the heat effected zone of the weld. Forgings; It probably depends on the surface finish of the part, but I have never had an aluminum forging anodized. i suspect the 'skin" that is present on the surface of a forging might keep it from acepting very much color.
scottk
http://www.dupli-color.com/products/metalcast.html
Check it out, they also make a ceramic coat I've used (cure in your oven!) looks awesome, we'll have to see how it holds up..
Scott
Scott
- Mitch
My Angel LCD paintball gun is done in a awesome job.
- jasonb
Mitch,
You live in CO Springs and play paintball. Did you ever play tournament ball at RockyMountainPaintball? Maybe I've shot you (whoops, meant to say "marked" you) before.
