Balancing pistons
Balancing pistons
Anyone ever balance there own pistons? I know of a few people but I really want to do this myself. Made enough mistakes in life ,one more wont hurt. Any pic..what size drill bit? Any experienced help would be great.
- Marty
Balancing pistons
I do but I dont use a drill bit. I use an endmill in a mill and remove from underneath the crown.
Marty Staggs
www.staggsracing.com
Marty Staggs
Balancing pistons
Hopefully you can achieve a good balance without having to remove material from anywhere but the balance pads that most pistons have for that purpose. Avoid removing material from the underside of the pin boss if you can, and don't leave any sharp edges that could be stress risers. I normally use a rotary file on a high-speed handheld grinder. If you have a gram scale it should be a piece of cake, otherwise you'll need to rig up a balance and cross-check them all. Don't forget that the wristpin weights may vary so they need to be kept with their pistons (and a little pin juggling may save some time too). Normally rings and wristpin clips won't vary in weight enough to matter unless you're extremely anal. Anything within a couple grams is adequate (Stock Porsche spec is 5) so don't panic if you go a hair too far on one.
Balancing pistons
There have been tech articles in Hot vw and Vw trends about it, at least in the 80;s when I subscribe regularly.
Balancing pistons
Marc, I have a digital scale that reads to the nearest gram. Is that good enough to do pistons? ( all to within 1 gram of each other) ?
-Les
-Les
Balancing pistons
What type of end mill bit. I have access to a drill press so I can buy the bit.
- Marty
Balancing pistons
4 flute with 1/2" diameter is what I use. 1 gram is fine. I sure have not seen "balance pads" on VW pistons.
Marty Staggs
Marty Staggs
Balancing pistons
QUALITY SCALE SALE ENDS AUGUST 2, 2002..www.discountscales.com..OHAUS MODEL #CS2000..$60...2000grams..1gram increment..weigh your pistons,lifters,rods..(.1GRAM INCREMENT SCALES ALSO AVAILABLE)
Balancing pistons
SCALE SALE ENDS TOMORROW...www.discountscales.com
Balancing pistons
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Marty:
<B>I sure have not seen "balance pads" on VW pistons.
</B><HR></BLOCKQUOTE>
Gee, now I'm worried...I wonder what I've been grinding away all these years?
- Marty
Balancing pistons
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Marc:
Gee, now I'm worried...I wonder what I've been grinding away all these years?<HR></BLOCKQUOTE>
Beats me.
Wrist pin boss? LOL
Marty Staggs
Beats me.
Wrist pin boss? LOL
Marty Staggs
Balancing pistons
On a mahle piston thats not a balance pad, it is an indicator of the direction the piston should be installed. After thoyusand of miles the arrow gets carboned away and they want a definite way for the installer to install the piston.
I do just like Marty and use a 4 flute endmill under the crown. I have been seeing Mahle sets way out on my balancer lately, as much as 20 grams between 4 pistons.....that much of a variance means unboxing 5 sets and tossing them into sets acording to closer weight out of the box.
My spec is .5 grams per 4 pistons more than that and you can feel it..Balancing is important..
Jake Raby
Raby's Aircooled Technology
www.aircooledtechnology.com
Jake Raby
Balancing pistons
Jake Raby, You are the King! Anal has met it's match in this case! *L* .5 grams per set? Would buying P/C's from GBE be better then since you get POTL P/C's? Or do you do all the machining to get POTL's yourself? BTW when I move back to Tennessee next year I am coming to see you!
John
John
Balancing pistons
The hard part, of course, is making sure that the EXACT same amount of oil clings to each piston & enters each wristpin and that the EXACT same amount of carbon builds up on each piston. Otherwise you can feel it....
Balancing pistons
A sense of sarcasm in the air....Great!
if the engine is built correctly and ran hard enough there won't be any carbon buildup on the pistons!!lol
Yes, there is a .2 gram per inch of bore equation to correct for oil on the pistons backside on my bobweight card. The recip factor is also based uopn weights of the rod bearings being used and even the oil that is displaced by the rod bearings, based upon the crankshaft clearances....this is no exaggeration, just the reason my CNC balancer cost 30K...
Jake Raby
Jake Raby
