Head temp gauge
robert66bug
Head temp gauge
Post by robert66bug »
How do the sending units work, do they all need to have a hole drilled in the head?
I have the Superflow heads...how should i go about getting a temp gauge on them?
Sidewalk
Head temp gauge
Post by Sidewalk »
The sender is like a washer that goes on the spark plug.
'88 Bronco II - Sonja
'59 Bug - Stella
'00 Buell X1 - Liz
"Yes, I am a smart ass."
"I'm a DUMBASS too"
But are you gutless?
Tom Perso
Head temp gauge
Post by Tom Perso »
Just remove the washer from one of your plugs and use the thermistor instead. Everthing will work out fine.
Later,
Tom
KgHiA71
Head temp gauge
Post by KgHiA71 »
Just curious, what is the ideal temperature for cylinder heads anyways?
http://kghia71.8k.com/
Eaallred
Head temp gauge
Post by Eaallred »
I've been told 425 is the 'limit'.
My 040 welded heads never got over 350, even in 120 degree heat. Well, except that time I tossed the belt at 7K
Eric
64 Bug
64 Bus
superdrag73
Head temp gauge
Post by superdrag73 »
I use the style that goes under the spark plug. I'm gonna add a question though: Does having one plug sitting a little higher cause a problem? Haven't noticed any.
Sidewalk
Head temp gauge
Post by Sidewalk »
Only problem is if you index your plugs. Most people don't do that.
'59 Bug - Stella
'00 Buell X1 - Liz
"I'm a DUMBASS too"
Head temp gauge
So, where do you get the sensors?
Eaallred
Head temp gauge
Post by Eaallred »
Aircooled.Net has the gauge and sender, and just the sender seperatly.
Eric
64 Bug
64 Bus
Eaallred
Head temp gauge
Post by Eaallred »
You can, but you'll get more accurate, and quicker readings from under the #3 sparkplug.
Eric
64 Bug
64 Bus
ppp
Head temp gauge
Post by ppp »
can't you put the probe under a head nut?
ppp
Head temp gauge
Post by ppp »
is #3 the hottest?
Eaallred
Head temp gauge
Post by Eaallred »
#3 is usually the hottest.
I should rephrase what I said about the accuracy. Wether the sender is under the plug, or the head bolt, it will read the temp at that location, just under a plug, will give a hotter reading.
Eric
64 Bug
64 Bus
ppp
Head temp gauge
Post by ppp »
ok...one more for ya'...i'm measuring the rich/lean at the exhaust and the oil temp.
is there any reason to gauge the head temp while using these other two measurement? if so...what are the bennits?
Eaallred
Head temp gauge
Post by Eaallred »
Cylinder head temp gauges read MUCH quicker than an oil temp gauge. You can see a difference in the temp after hitting the freeway onramp. They're sweet.
Eric
64 Bug
64 Bus
