Sealing an engine case?
74EMPI
Post by 74EMPI »
What is the best product to use for sealing the case halves. I thought this was discussed previously but my search didn't turn up the thread. Thanks!
FUgly
Post by FUgly »
Gasgacinch
Eaallred
Post by Eaallred »
Gasgacinch is sweet, but I have a helluva time finding it local.
i've used Permetex "Super 300" with good results also.
Eric
64 Bug
64 Bus
Marty
Post by Marty »
Curil is the best stuff. It does not dry and seals perfectly.
Marty Staggs
www.staggsracing.com
74EMPI
Post by 74EMPI »
Where would I find gasgacinch or curil. Pep boys, autozone????
melbatoast
Post by melbatoast »
anybody ever try the Black RTV? this stuff is used by some of 'the big 3' in place of actual gaskets; i.e. diff covers, etc.
arlan
you see these?
they are my carkeys.
you will never get these.
Marty
Post by Marty »
Do NOT use any kind of RTV or silicone on the case halves.
You can find Gaskasinch at Pep Boys and Curil from Berg.
Marty Staggs
rich2481
Post by rich2481 »
RTV is too thick, the cases are or should be matching surfaces. I use Permatex High tack, is like contact cement,
74EMPI
Post by 74EMPI »
Thanks Marty!
Post by MASSIVE TYPE IV »
Loctite 518......or Curil K2
Jake Raby
Raby's Aircooled Technology
www.aircooledtechnology.com
max, Der Bahnstormerz
Post by max, Der Bahnstormerz »
I use Wurth engine sealant on the case halves and Elring Dirko S on all the rubber seals, and Wurth hi temp scilicone at the barrel bases
britegreenVWSB
Post by britegreenVWSB »
Permatex Forms-a-Gasket is what I always use. Otherwise known as Aviation Sealant. A VERY thin coat is all that is needed.
TG
Milt Damnit
Post by Milt Damnit »
i like the k-2 curil or the permatex i think it's the 3H or part # 80019. both of these are a semi drying sealant that will push out of the case halves and allow them to seal to each other.
i don't like to use RTV because it will begin to dry and lump up and actually prevent the case halves from sealing to each other properly.
just my 2 cents worth
afew years ago I quit using permatex aviation, after I realized it was only good for 1200 hours, then it starts to seep..1200 hours is one helll of a long time, but when my 200K engine in my 62, 15 window started seeping I knew it was true.
melbatoast
black RTV is out! :~)>
arlan
you see these?
