>>>for kicks could you up the compression on DJs engine to 9.25:1? TIA<<<
hi john,
142hp@6k, vs. 149hp@6k
torque is 137@5k, vs. 143@5k
bmep is 162.8, vs. 169
>>>if i was to build a type 4 motor with a counterweighted 71mm crank and 103mm bore
2366 ccs... or i could make a 2332 type 1..would they make close to equal power?<<<
2366.37(71x103) vs. 2366.19(94x85.24):
148hp@6k vs. 144@6k
torque
[email protected] vs.
[email protected]
bmep 158.8 vs. 157.1(!)
lets increase head flow(aircooled.net stage7, 44x37), c.r.(9.25), and cam profile(fk87), 48ida's:
182@6k vs. 179@6k
torque 180 vs. 178
bmep 190.6 vs. 189
i'd be glad to send these dyno files to anyone who has the dyno2000 software, so you can check the results for yourself... maybe i made a mistake
like i posted before, there are no mathematical h.p. advantages to rod length; but longer rods do provide less side loading of the piston, and they have been proven on numerous dyno tests to give more power.
remember that the holy grail of head porting is to always achieve the magic % ratio of input vs. output cfm... nothing else matters... in the case of the stock type 4 head, bigger valves will only help up to the point where you cannot compensate for the limited flow design of the exhaust port, and it alters the i/o ratio.
by compensation, i mean using the iterative testing feature of the engine math program to design a type 4 exhaust lobe profile in the cam that will increase the exhaust flow... but when does increased duration turn into flow reversion of the combustion chamber?
torque is not a factor when overall displacement is the same, because with the better flow %'s of the type 1 head, i can use the engine math program to design a cam that produces torque wherever i want it... i could even tell the head porter to make the flow ratio whatever i wanted it to be, i.e., match the i/o cfm of a type 4 head.
dan
oceanstreetvideo.com
