Aftermarket cases.
Tom J
Aftermarket cases.
Has anybody had any experiences running an aftermarket case on the street? I maybe looking into a Scat Killer or Autocraft case for my bug, cooling would be 911 fan. Before you all say I'm mad or a waste of money it's just an idea. Cheers from the UK.
marco the steem engine
Aftermarket cases.
your f%c&ing mad and what a waste of money!
WHAT A GREAT IDEA!
lets see if you can split the B piller on a pre 63 bug and show Max what power is about!
WHAT A GREAT IDEA!
- bad62bug
Aftermarket cases.
My buddies Car runs a scat case It's a 2920cc he drives on the street 10 to 1 cr
> Dynoed by Dave Kawell @ 255hp @ 6000rpms max hp is much higher cam is bigger than a fk89 kewell only took it to 6000
GDRBO
Aftermarket cases.
A friend makes a new aftermarket case. Ken Majors built a 2234cc motor based on my friends case and said it was like assembling a stocker (no clearancing or special fitting required). They were not building anything special they wanted to build a bolt together motor like anyone could build a stock 1600. I don't know what cam they chose but they weren't looking for big HP, just a large displacment easy assembly motor. It made 165 hp on the dyno with no special tuning. If you want more info call 619-596-0886
Steve Arndt
Aftermarket cases.
Consider the wasser case as a possible option.
Steve
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Tom J:
Has anybody had any experiences running an aftermarket case on the street? I maybe looking into a Scat Killer or Autocraft case for my bug, cooling would be 911 fan. Before you all say I'm mad or a waste of money it's just an idea. Cheers from the UK.<HR></BLOCKQUOTE>
Steve
Tomj
Aftermarket cases.
Thanks guys, I am probably going to go for the Scat case with the possibility of using a roller cam set-up, any bad news out there for roller lifter/cam. Apparently it has been done but just costs $$$$. But maybe this will be cheaper than a flat cam with all the stress and broken parts that goes with that senario.
p.s Steve, Marco has been trying to convert me to the wasser way of thinking!
- Searoy
Aftermarket cases.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Tomj:
<B>Thanks guys, I am probably going to go for the Scat case with the possibility of using a roller cam set-up, any bad news out there for roller lifter/cam. Apparently it has been done but just costs $$$$. But maybe this will be cheaper than a flat cam with all the stress and broken parts that goes with that senario.
p.s Steve, Marco has been trying to convert me to the wasser way of thinking! </B><HR></BLOCKQUOTE>
OK guys.
Why would you NOT want to switch over to a wasser case? I know the arguments FOR getting one, but I want to hear the naysayers tell me why wasser cases suck.
Beuller? Beuller?
*** Teach a Man to Fish ***
Searoy
OK guys.
Beuller? Beuller?
Searoy
fastfood
Aftermarket cases.
Searoy, tell me about using a wasser case. Is there something in the Forum already to save you some time. I'm assembling a 78X94, and would rather use a stronger case. It makes sense that it would be stronger, i thought the cranks were completely different. Thanks for your assistance.
Rice, it's what's for dinner!!!
GDRBO
Aftermarket cases.
Is the cam dropped .100 in a wasser? If not really long strokers that will fit aftermarket cases won't fit it.
- Searoy
Aftermarket cases.
Look for the VW Speed and Drag Racing thread named "Wasser crank in Type !." The last post (at the time of this writing) is mine, and tells just about all I know about the wasser case, and where I got my information.
Searoy
Searoy
- Searoy
Aftermarket cases.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by GDRBO:
Is the cam dropped .100 in a wasser? If not really long strokers that will fit aftermarket cases won't fit it.<HR></BLOCKQUOTE>
I'm no aftermarket case wizard. Do ALL aftermarket cases have dropped cams, or is it just possible to machine them so that they are? The wasser case can be machined so that the cam is .100" lower. I want to say Fred said it would go .150" but I will not quote him since I do not remember exactly. Perhaps it was when he was talking about the Perf Tech case that would go .150". Or maybe I'd had too much 151... ;p
Searoy
[This message has been edited by Searoy (edited 08-31-2001).]
Searoy
fastfood
Aftermarket cases.
Searoy, thanks for the assist. Found the section you are talking about, heading to the local boneyard to get the 2 that I know are there.
Steve Arndt
Aftermarket cases.
90mm stroke will fit.
Steve
Steve
Ross
Aftermarket cases.
What about the water jackets? I know there is a car over here that has had them removed and put "normal" air cooled cyls in place but i imagine that its not too easy?
Any comments?
Ross Holding
Any comments?
Ross Holding
- Searoy
Aftermarket cases.
I don't know the procedure, but I figure it's actualy pretty simple. Band saw cut off the jacket/cylinder combo, and bore for cylinder holes. What else is there? Recylce the aluminum and buy a few beers.
Searoy
Searoy
