Thanks Thomas, I do not even have to post anymore
LOL
I should be getting the rest of the kit from Old Speed this week! There are a couple parts that are custom that must be purchased from Old Speed like calipers mounts, bearing spacers, and grease caps.
Also there are a handful of other items you will need on hand as well, but Thomas hit all the main points.
The front 944 calipers I am using are from a 83-85.5(86?) 944. If you go to the later 4 pot system I am not sure how it will fit on.
This is not a cheap conversion! Once you add in wheels(Fuchs), tires, rebuild stuff, bearings, shocks, blah blah blah... You will basically be at about $1000 just for the front axle, plus or minus of course. I think it will be worth it big time, but I drive my bus a lot so better braking is worth its weight in gold.
The rear is tricky... Thomas let me know how your experiment turns out! Sounds very interesting, I thought the RGBs would be to restrictive to get the 944 brakes on there? My initial plan is to get a T1 tranny and do the IRS conversion. With this you pick up T1/T3 rear brakes which are very easily swapped to the 944 rears. The trick is keeping it stock height which is important to me.
Actually I think once the front brakes are done I will focus on CIS FI conversion (regular 1600) for a while and then get back to the rear end issues this fall.
Adrian Pillow
'66 VW Westfalia - "Biscuit"
'67 VW Deluxe Westfakia - "Dino"
'79 Porsche 911 SC - "Cochese"
