Broken tangs on brake adjuster
- david58
Is there a fix for this besides a new backing plate?
Bugfuel
- bugman742002
- bugninva
- david58
How did you find that?bugninva wrote:http://www2.cip1.com/ProductDetails.asp ... %2D185%2DA
- Lew
Now, do we grind off the one left and tack weld the new one in place
It's still in the Restoration Booth!
You can take a peek!
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
- bugninva
hahahaha... they've been available for years, so I just opened a couple suppliers' sites and searched "brake adjuster".. .knew I'd find it... got it on the second one...david58 wrote:How did you find that?bugninva wrote:http://www2.cip1.com/ProductDetails.asp ... %2D185%2DA
- david58
I searched too till I was exhausted.bugninva wrote:hahahaha... they've been available for years, so I just opened a couple suppliers' sites and searched "brake adjuster".. .knew I'd find it... got it on the second one...david58 wrote:How did you find that?bugninva wrote:http://www2.cip1.com/ProductDetails.asp ... %2D185%2DA
- bugman742002
- Lew
72 Brake Adjusters
I finally got some parts from California Imports, and in my order was a couple of the so called "Brake Adjusters". In their discription, "Welding Needed". No so for me. On the rear backing plates, I had one where both ends were broken off near the offset, and on the other rear, only one side was broken off.
What I did to remove the first broken piece, was use a small nail set to drive out the remaining piece. Surprisingly, it came right out with a few sharp taps with the hammer. Once I cleaned the area I could see that all I had to do was slide my new part under the pinged area, which was the side nearest the backing plate, and tap down on the opposite side.
It snapped in place with the first tap. It's nice and tight, and will not move. I am sure it will do it's job keeping the star adjusters in place.
I'll tackle the other side tommorow.
You can see where one of the broken adjuster was after I removed it.
A little better view!
A new Adjuster but not installed.
A easy fix and just like new!
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
- Glenn
It's funny that this post came up, I just did the same to 2 backing pates for a friends car.
I got mine from Wolfsburg West.
http://wolfsburgwest.com/cart/DetailsLi ... 211609185a
