A little history: It all started as a bog standard Glass bodied 'dune' buggy about 15 years ago. Each year saw many upgrades, all getting compromised by the VW pan, and the previous development. So three years ago I decided to take the old girl off the road and sort out the compromises.
I bought a load of 2" 3mm wall tube, some of which was CDS (DOM) for the roll hoops. I went 2" cos it's going to be a 'woods' buggy and have the kids in, also I'm a woos in the 'getting my skull stoved in' dept. I also invested in a JD2 manual bender, their notcher, and a 215 turbo mig. I had all the rest for a bit of fab work.
Spec was to be, 002 bus trans (091's are rarer over here if I break the 002 I'll upgrade), 5x5 rear arms (diy), Rover (buick) 3.9l V8, longish travel LP front end. Four seats and longish wheel base.
I've nearly cracked the rear suspension, but had no end of trouble working with the chromoly torsion tube I used, due to it's use of the original VW geometry. I ended up 'spitting out the dummy' and hacking off the inner trailing arm mounts and making it dual pivot.
The frame is tacked - so necessary as I've had so many R&D issues along the way. It's got a bit of fine surface rust, as it had a holiday between house moves and the northwest UK weather wasn't friendly!
Some piccies:
The 5x5 arms as I first made them. jigged from the original VW arms.
The inner pivot, showing the welds I am capable of. I'm looking to improve, any pointers gratefully accepted. I'm happy with the strength, I know there is total penetration because I had to cut them off again to make them dual pivot. What I struggle with is keeping a consistent bead as it goes round the tube. i have to stop, move the part and restart. This causes lumpy bumpy stuff, not pretty.
i had to go from this set up:
To this:
The arms have been hacked through ready to get the hubs accurate for toe and camber - something i just couldn't do with the standard VW chassis mounts.
I've read through STF ORF threads for several months now, checking out the various readers rides, Im looking towards a useable (road and trail) buggy that is aesthetically pleasing. How am I doing for starters?? Any things I should be aware of?
