Hi. I took my swingaxel gearbox apart and found that on of the 3 pipes holding the spider gear axels in place had broken. I was able to take out the two short axels that holds in place two of the spider gears (I run a superdiff with four spider gears) and they spin nicely on the axels. Now I have the long axels with the last two spidergears sitting in the diff. The thing is it seems that atleast on of the spidergears has seized on the axel, and I cant punch out the axel. My question is, has anybody had similar problems like this? How do I get the axel out? And is it possible to buy a new axel to replace the one that obviously must be brooken?
Any input will be apreciated.
Thanks in advance.. Jakob
Superdiff problem
- dangerous
Hi Jakob,
I see this problem quite often,
and in most cases the shaft has to be drilled out with carbide or cobalt drills before pressing out.
I did save one recently by just pressing the shaft out,
but this is not the norm and can ruin the main housing(cast iron),
if it is not supported properly.
Most often cause is one wheel burnouts, and lack of lubrication.
Check first that the oil holes are ample(or even there at all)
and don't be afraid to add more.
I have recently also been using a teflon/moly coating on the shafts and spiders,
and giving the spiders an extra thou of clearance before the coating.
Looks OK so far.
Shafts are around used, and weddle may stock some,
but I just use VW ones,
and cut them to length and
re-drill them for the roll-pin ("3 pipes")size that your diff uses.
I use tungsten drill first,
and then a 1/8 drill after getting through the hard layer.
Larger pin diffs may be able to use the original VW roll pin holes.
I think the VW shaft has better hat treatment,
but gotta have the oil in there
and it is hard to get as much oil in there as a stock housing can
with the two extra spiders and shafts filling the void in the body.
Looks OK so far.
Getbackontrack
Thanks for your post Dangerous.
I will try to drill out the axel, just to be sure not to break anything.
When I look down into the housing I can see that the surface up to where the spidergear runs is a little marked, like one of the spidergears has run hard up against the housing. it is not very deep or anything, just tiny little scratches all way around. Does that meen my houseing is junk?
Jakob
Jakob
Getbackontrack
Got the last axel holding the last 2 spidergear pressed out today, 10 ton was what it took to press them out. But I broke the thing in the middle that holds the two axels inside the diff, Anyone know if its possible to buy that part alone? I found a new axel and two fine spidergears in an old IRS diff I had laying around, assume I can use them in my swing diff, right? They look just the same.
Jakob
Jakob
Getbackontrack
Bruce2
