First, the specs:
* 412 Coupe 4 speed daily driver
* 2056 cc Type 4
* 9550 RAT cam
* LE-180 heads (914 2L combustion chamber, 42mm intake, 36mm exhaust)
* Mallory Unilite vacuum advance distributor, Mallory Promaster coil, Mallory Hyfire CDI
* Stock 412 heater boxes & Thunderbird exhaust (until Tangarine Bus Header is available from RAT)
* 2L Bus plenum and throttle body
* 2L 914 runners
* Ford "Design II" F1TE-D9A (Bosch 0280150947) 24# injectors (modified)
Ross at SDS was very helpful in answering my pre-sales questions and the system with custom wire harness was delivered in a few days. The ECU will be housed in a gutted D-Jet ECU box located in the stock location for the 412 Coupe (left rear quarter panel). The box is fluid tight and should not be a problem. I made a custom DB9 cable to extend the SDS Programmer into the cabin (right connector).
A harness was made to include SDS, new gauges, and CDI under rear seat. A second engine bay disconnect will be added for TPS and ET for easier engine removal. The MAP sensor will be placed on the firewall and the AT sensor will be placed in the stock air cleaner.
I plan on installing the SDS on the stock engine so I can learn how to tune on a "disposable" engine (I got it for $25) while I assemble the 2056.
Helpful tips and comments welcome,
Bill
P.S. edits in bold
