After discovering the rusty frame horns on my 1971 Super I poked around some more on the chassis and found a rusty frame head and a LOT of rust that had been patched with scraps, screws and tar by the PO. SO, I pulled the body off the pan and rolled a standard pan under it-without the beam. There was a bracket under the frame head that had to be cut out, because it interfered. I have cut out bits of the spare tire well for clearance-and more will have to be cut once the beam is slid into place. So, for those of you with Supers that are solid, but want to go with them as an off-roader, this is an option since you would be cutting out most of this anyway. This was EASY. I saw so many posts that said it would be TOO much trouble, here is some FIRST hand experience. If you are going off-road and you have a Super that you want to use, a standard pan WILL work, with few issues. A one-piece front end will work once you cut out the inner fenders or a Super Baja kit will work also. I have heard rumor that a bug eye kit will work with a chopped stock hood and some modded fenders, but I have not had opportunity to give that a try. Here are some pics to give you an idea.
This is on a VERY mild baja. VERY nice low-mileage 1974 pan/engine. 1971 Super body. Just something for the woods, trails, fields and street.
Would anyone be kind enough to measure the width of a baja nose piece for me? I may try to use a bug eye kit, some chopped fenders and a chopped hood.
