Cooling the Engine
Moderator: david58
rsb
Post by rsb » Sun Mar 02, 2008 4:09 pm
aussiebug
Post by aussiebug » Wed Mar 05, 2008 6:52 am
http://www.vw-resource.com/cooling_system.html
Probably has just about everything you need to know about the cooling system.
Regards
Regards
Rob
Rob and Dave's aircooled VW pages
Repairs and Maintenance for the home mechanic
www.vw-resource.com
Kenny2428
Re: Cooling the Engine
Post by Kenny2428 » Wed Mar 05, 2008 11:01 pm
MNAirHead wrote:
rsb wrote:Anyone run across, or participated in some really informative dicussions of cooling? For example:
3.1 Cooling.
3.1.1Cooling tin.
3.1.2 fan.
3.1.3 thermostat.
3.1.4 warning light on.
Did I miss anything?
  • Removing cheap parts
    Timing it correctly
    Setting up the correct carb
    Removing obstructions and mouse nests
And making sure the fan belt tension is set correctly- to loose it will run hot, to tight the belt will slip at higher RPMs, and make it run hot. To adjust the belt tension, the pulley nut is removed and shims are added to or subtracted from the space between the pulley halves. Adding shims decreases belt tension, and subtracting shims increases belt tension. There should be about 1/2" of tension in the belt.
