Very Nice!
You can guess that i might have some questions
Is that front tin - the one over the bellhousing (clutch area) fabricated,or modified from the existing? Very tidy.
Would also love to see the mounts where the rear hanger bar attaches to the rear mounts.. you use the factory rear rubber mount pieces at the body?
Oh, and please do find the pic where the bellows attaches. Was scratching my head looking at those parts yesterday...
Was looking at how the factory also takes the carb intake air from the body ducts, too.
Was going to add another just like it on the other side, one for each carb.
Will have to fab airboxes...
How is wheel hop with that setup?
Nice that you have a rear "traction bar" that is actually strong enough to take the whole weight of the engine!
Is that enough to keep the notorious type 3 wheel hop at bay?
Because the whole subframe mounts on rubber, a "kafer" style bar would be of little benefit, as the shock towers are rubber mounted, too.
The factory mounts at the rear seem kind of soft, though, and i wonder how they would take the uplifting forces that the left side will see at launch..
Was trying to figure out some solid mounts that would bolt on, and tie the subframe directly to the body for track duty.
You would then remove them for daily use when wildness was not part of the program...
Also,
Are the small rectangular ports that would normally feed the heater boxes sealed off?
It looks like they may be setup to bleed a little...
It's been said on the forums here that they need to be open, or the cooling system will not be as effective.
The Vanagon shroud is a sought-after item by people running a header for this reason - it has those ports gone, and the internals adjusted accordingly to not compromise cooling.
Oh, and the oil fill - Nice!
I take it bus and T3 parts joined?
What is the tank on the left? Breather?
Also noticing (about an hour later
) the welds/plate on the left side by the rear mount. Fixing rust, or something more?
Dag, i just love it. Do you have any pics of the build up on the web somewhere?
It really shows some forethought.
