I cannot visably see where the leak is coming from. There is a drip from the from the front end about 2' from the front bumper.
All of the rubber and steel lines are dry, I have pulled the left front tire and the MC seems dry but old and rusty. I also have brake fluid that has blown along the right side if the floor pan so I am sure that the leak is comig from the front. I have a new MC to install but I would really like to visably see the actual leak.
Any ideas?
Thanks for the help!
72 sb vert
Brake Fluid Leak
- bugman742002
Thanks for the replies...my guess is the pushrod...I have a small amount of fluid around the pedal cluster...I just wasnt sure if it was brake fluid or all of the WD-40 that I spray in that area on a regular basis...the majority of the drip is coming from the weep hole in the FRAME HEAD...so hopefully the fluid is coming from the pushrod...
Thanks again...
Thanks again...
