6V Gauges in a 12V world
- Dangermouse
I’d like to install a couple of electrical gauges in my 6V beetle, maybe cylinder head temp or oil temp and oil pressure. In the absence of 6V gauges, can I use a 6-12V voltage converter to power them?
What about the sender units, do they require their own 12V power supply also?
I like the look of the VDO Series 1 gauges for resemblance to stock, coupled with a dual terminal sender to operate the oil gauges and idiot light, like this arrangement...
https://secure.cbperformance.com/catalo ... ductID=837
Is this at all doable?
- Speedy Jim
Yes, it's doable.
You will need a (small) 6V to 12V Inverter.
Only the gauge needs 12V, not the sender.
Some possible sources:
http://www.thesamba.com/vw/archives/man ... verter.php
(Don't know if it's still made.)
This is a DIY:
http://www.aaroncake.net/circuits/6-12conv.asp
and:
http://www.elecfree.com/electronic/lm25 ... regulator/
Another approach is to get a very small 12V battery, like motorcycle,
to power the gauges. Recharge when needed.
Also possible to use a small 6V battery, charge from the car and
then series for 12V out. Getting complicated....
Speedy Jim
http://www.nls.net/mp/volks/
This is a DIY:
and:
Speedy Jim
- Dangermouse
Thanks Jim, I was hoping you'd chime in
I was going to use one of these...
http://cgi.ebay.com/ebaymotors/ws/eBayI ... %26fvi%3D1
which gives me 5A to play with.
In a similar vein - if somewhere down the line, just for giggles, I wanted to install an electrical tachometer also, do you think a 6V input signal at the coil would allow the gauge to function properly?[/url]
- Speedy Jim
- Dangermouse
This seems to have worked out quite well so I thought I'd report back for other 6V users who might be interested...
The voltage converter seems to be a good little piece of equipment and appears to do its job well...
Here it is mounted on the back of the radio...
The VDO Series 1 gauges came from nhspeedometer.com who provided excellent service. The only modification was that I asked them to replace the gauge bulbs with 6V equivalents so they could be run straight off the light switch as normal.
One small mistake (which may have been a misscommunication on my part); spot the deliberate error...
Oil pressure and temp senders in place. I was mindful not to overtighten the tee fitting into the engine block for fear of cracking the case so I just kept giving it an extra quarter turn until it eventually sealed and stopped leaking.
I did attempt to run the wires up through the roof channel alongside the wiring loom but had to give up. There was no way I could get a fishtape to feed through. I compromised and ran the wires inside the body, under the back seat, along the floor pan and up into the front just forward of the door pillar.
Here's the gauges in place; I'm happy with the finished result.
Hardest part was trying to figure out how the mounting cups go together; still not sure I've got them right...
Oil pressure, temp and CHT are all functioning well. The bulb on the CHT gauge blew straight away which makes me wonder if it was indeed replaced with a 6V one, the others are all holding steady. I guess I'll just have to just replace that bulb, no biggie.
The tach, while it is functioning, is not reading quite accurately just yet. The diagram of the micro-switches included with its instructions seemed to be reversed so that at first it was registering 2,000 rpm at idle. I had heard about the irregularities of the VDO instructions though and was ready for that one. I believe its now set properly for 4 cylinders and I've got it reading about 500 rpm at idle (actual idle speed as measured by my DMM is closer to 850). The potentiometer on the back allows for some degree of fine tuning but not that much. Its quite steady though.
Any suggestions Jim?
- Speedy Jim
Nice setup and nice writeup w/pics!
Love the H2O temps gauge. LOL
I wonder if the inverter could be causing the tach to mess up.
Try a 12V battery feeding the gauges, as a test.
If not that, maybe the signal from the coil is deficient as far as
the tach is concerned. Post back if the 12V battery solves it or not.
May have to come up with a circuit to drive the tach (hope not).
Speedy Jim
Speedy Jim
- Dangermouse
Yep, I decided to keep itLove the H2O temps gauge. LOL
No change when supplying the gauge with a 12V battery feed unfortunately.Try a 12V battery feeding the gauges, as a test.
I suppose a very easy test here would be to just hook the tach signal wire to a 12V coil on a donor vehicle and see if that changes the state of the signal? It would rule it in or out at least.If not that, maybe the signal from the coil is deficient as far as
Sounds ominous...May have to come up with a circuit to drive the tach (hope not).
- Speedy Jim
- Dangermouse
Just to revisit this one briefly...
I did end up trying to connect up the tach on a 12V donor vehicle, I just backed a friend's beetle up beside and ran a wire from their coil to my tach sender; it didn't help (if anything it was worse). I wasn't sure if there needed to be some sort of common ground connection between the two vehicles for this to have worked, I did try connecting the two bodies together with another wire but there was no improvement.
The tach (and the other gauges) continues to function well, if inaccurately, and I has happy to leave it at that and not pester Jim further...
Then the other day I spotted this in an electronics catalogue -
http://www.jaycar.com/productView.asp?I ... &SUBCATID=
Is this the sort of circuit you were thinking about? It reads...
"Speedo Corrector MkII Kit - When you modify your gearbox, diff ratio or change to a large circumference tyre, it may result in an inaccurate speedometer. This kit alters the speedometer signal up or down from 0% to 99% of the original signal. With this improved model, the input setup selection can be automatically selected and it also features an LED indicator to show when the input signal is being received. Kit supplied with PCB with overlay and all electronic components. "
I don't know if there's a difference between the signals for an electronic speedo as compared to a tach; do you think this could be used for my application?
- Speedy Jim
- Speedy Jim
- Speedy Jim
