honda vfr bodies
pantswagen
honda vfr bodies
Post by pantswagen »
-there already split
-cable linkage = good
-fuel rail already done = goood
slowtwitch
Post by slowtwitch »
I'm going to try them on a stock 1.7 type 4 build that I have in the wings. Here's what I have so far...
pete
fl_buggy
Post by fl_buggy »
The bores look pretty close. How close are they? Any stumbling blocks you've found so far?
findog78
Post by findog78 »
I need a pair of these too!!! Let me know if anyone has some sitting.
How big are those butterflys?
slowtwitch
Piledriver wrote:How big are those butterflys?
They are 36mm and the spacing, center to center, is 90mm.
pete
pete
Should work great on a mild 1.7-2.0.
pploco
Post by pploco »
Resurrecting an older post here. What "honda" are these found on?
fl_buggy
Post by fl_buggy »
VFR. I know there was a VFR 750, not sure if there were other sizes made anywhere else. Its a V4 motor which is convenient for our use of the TB's.
VFR, AKA Honda Interceptor, 750 and 800, pretty sure the 800s were all EFI.
pploco
Post by pploco »
Pile are you a freeBSD guy?
pploco wrote:Pile are you a freeBSD guy?
Na, Linux since ~1994, (On my Amiga3000 `till ~97)
I always set up spare partitions to play, but whenever I try any *BSD it's too much like going to France. (so to speak, nothing wrong with France, I 'd actually love to visit, blablabla)
I DID run NetBSD 1.0 back in the day for awhile as it had decent support for my A2410 video card, but too much of the software I needed wasn't available back then, and ~all the development was done on Linux... Need Latest version==Run Linux or port it yourself...
(WHY wasn't Pi declared in the BSD libc? I always hated that trivial annoyance...(Pre autoconfig IIRC))
Then RH5 shipped and I lived close to a Frys...
I have settled on running Mandriva for the last few years. Generally bullet proof as a desktop and media center/etc box, no RPM hell, fast and stable.
(decent as a server box too, with Webmin and freinds, OTOH so is ~every other flavor of Unix)
I'm a glorified mechanic now and haven't done any programing in years, sucked at it anyway.
Occasionally have to fix Win boxen, which perversely frequently is best attacked using a Knoppix CD...
pploco
Post by pploco »
Sortof a threadjack...but oh well.
Thats quite the paradigm shift for you - programmer to mechanic. I'm a wannabe mechanic posing as a network engineer by day. I too love the penguin!
John_S
Post by John_S »
cbr900 tb's on a 2276cc , i split them had a new spindle made , even kept the injectors
Slick!
How big are the butterflies, and what did you do to adapt to the Weber/Dell manifolds?
On a 2.3 ... ~42mm or larger?
(Suppose 40s would work to ~6Kish)
