first switch under the joy stick is the progressive toggle for off,ign,start next is the progressive toggle for off,running lights ,headlights.next is fuel pumps. then a 2 position toggle to select between my oil and water temp senders and last a manual fan override switch
as far as the lights go..... starting at the top alt light , systems alarm light ,hi/beam indicator , shift light , turn signal flasher
Yet another follow-up question. I see the use of terminal blocks at the bottom of the pic, is your way of setting up a car to use this area as the "brain" and then terminal block out to the various sub-harnesses that run the components on the car?
If the answer is "yes", then I will have a follow-up to the follow-up
tim although the fuses are not all installed in that pic thats it, thats all of them actually when finished i had one spare fuse for use later ..on a rail you really should not need more than 5or 6 fuses as far as restraining the spiral wrap i usually just put down a sticky back an use a tyrap I do on occasion secure the end of a spiral wrap bundle with a device called a strain relief
if you look very carefully to the left of that fuse block you will see the maxi fuse holder for the master fuse that protects the entire system
when scratch building a system the pictured little fuse block is my weapon of choice what I sometimes do is put one in for hot all the time circuits and one for circuits that come on with the key
those little fuse blocks come in 4,6,8,10 and 12 fuse configurations
DG its pretty much the way you describe it that terminal strip is the cross connect point between the out lying components and the internal switching devices
What you have to understand is that we build these control boards or systems on bench and then drop them in the car we usually do not use another terminal strip before we get to the actual device not to say it could'nt be done like that
the terminal strip could be cut down in size by going lets says directly to the component eg relay but we prefer to do it this way that also lets me bench test the whole board on the bench before i install it
Holy perfect bus bar BOB-O Wiring perfection. Nice ncie nice job, You need to go to the STS 181 foruma dn link Cliff to your work. HE is a charter memeber of RoMTOC and a retired electrician. HE has a Buggy and Thing is from Michigan but has some of the most sanitary wiring I have ever seen n a VW. BUT your set up is beyond anitary. Yours is complex and ZEN. Good job .....
