My blinkers don't work...
Mikerock
Yeah my blinkers don't work here are the symptoms.
when i turn the lever to left or right both blinker lights come on and stay on (on the dash not on the car)
Also when i hit the lever for the blinkers the gas gauge hits empty.
i pulled the fuse box out to check the relays, and there are only 3 of them. from left to right there are two black ones a missing one and then the relay for the lights.
i was told by another vw mechanic the furtherst one to the right was the "flasher" but i tried replacing it and nothing happened.
Any ideas??? maybe its the third one, the missing one. but on the wiring diagram it only goes to the fuses for the headlights....
- david58
Re: My blinkers don't work...
Also when i hit the lever for the blinkers the gas gauge hits empty. That looks like a ground path problem.Mikerock wrote:Yeah my blinkers don't work here are the symptoms.
- Speedy Jim
Fuse #2 is open or is making poor contact in the holder.
Replace it even if it "looks" OK, and polish the holder contacts.
http://www.hallvw.clara.net/vwwiring.htm
for diagram.
for diagram.
- Speedy Jim
That's the big clue.Also when i hit the lever for the blinkers the gas gauge hits empty.
The Fuel Gauge gets power from same fuse as the Turn Signal flasher function.
Use a tester to trace down why (likely a high resistance) the signals
drag down to the voltage to the fuel gauge as well as the flashr.
- Speedy Jim
Ah.the issue with the gas gauge went away
You may be down to a bad flasher relay, or open connection to it.
With the lever to L or R and Ignition On, check for 12V at Term #49 (+)
on the flasher.
Then check that Term #31 is properly grounded. Best way is to connect
a jumper wire from chassis to #31.
After that, replace the flasher.
Mikerock
Which one is the flasher relay?? because i tried replacing the furthest right one, and it didn't help. i guess it wouldn't hurt to replace all of them. also the third on from the left is missing. 56b which looks like a secondary headlight relay. i tried replacing 56a
on the diagram it goes from left to right.
S/56/30/56b/56a
S/56/30/56b/56a
- Speedy Jim
