Generator to Alt. swap
rickosuave1987
Post by rickosuave1987 »
Hey guys, the new engine I installed in my bug has an alternator already in it. So I was wondering, what do I need to do with my wiring to get my battery to charge. Can I just hook up the old wires to it? I saw a wiring diagram with what to do on it, but now cant seem to find it. :?
Baja
HookIt
SuaveRacing FaceBook
72bajaben
Post by 72bajaben »
take a look at this.
i can email it to you if you want just let me know.
rickosuave1987
Could you email that to me Ben? If I try to click and save it ends up being too small to read :?
rkraut (at) treila (dot) com
I dont remember where, but last week I came accross a site that had a ton of wiring info and what to do to swap the alt. Anyone know anything like that?
Last edited by rickosuave1987 on Thu Oct 09, 2014 9:02 am, edited 1 time in total.
Baja
HookIt
CopperBaja
Post by CopperBaja »
I remember seeing directions for it... I'll look.
I'm doing the same thing, but my engine has a generator.
Know of a way to pull the generator, without pulling the carburetor & manifolds?
*EDIT* I'm an idiot. :lol: Look on TOS on my build thread. Page 2.
Ignore "Jeckler" He's an A$$.
volkenstein
First up - what type of alternator?
Post by volkenstein »
Hi,
What type of alternator? Motorola externally regulated or Bosch internally regulated? For the first you must have the appropriate regulator (or substitute) and the second you just need your generator harness with a tweak or two and some connectors.
The samba has a sticky about pulling tinware or not etc etc in the late model forum. Yeah you can do it "in situ" but it's not as simple as people make out. Make sure you have two 10mm hex head bolts in the lower holes of the backing plate tinware. At least then you'll be off to a good start!!
Volkenstein
rickosuave1987
Re: First up - what type of alternator?
It is internally regulated. What are the "tweaks"? All of the gen. wiring is there still.
Baja
HookIt
volkenstein
the tweaks
Hi,
You need to put a blade connection on the green wire first (at the alternator). The brown earth (that used to be on the gennie) can stay as is, as can the heavy current wire.
Under your back seat, you need to join the 3 heavy wires (alt, battery, forward harness feed) and join the green and blue idiot light feed together. You can connect the brown somewhere.
SpeedyJim has a great little diagram for this on his website:
www.nls.net/mp/volks/scheme/gen_alt.gif
Exactly how you do it is up to you.
Volkenstein
rickosuave1987
Thanks volkenstein, that was the website I was looking for this past week.
Baja
HookIt
72bajaben
Post by 72bajaben »
it doesnt work for me. I emailed that diagram to you.
rickosuave1987
72bajaben wrote:it doesnt work for me. I emailed that diagram to you.
Got it thanks. Makes my life a bit easier now :lol:
yea, clicking on that link wont show the image, but here is site
http://www.nls.net/mp/volks/htm/elec.htm
link should work
Also, here is that diagram for anyone else who needs it.
Baja
HookIt
MNAirHead
Post by MNAirHead »
great pix .. thanks.
volkenstein
Oops..
Fellas,
Sorry about the dud link... :oops:
Here's a little food for thought to connect everything up under the back seat:
Just some aluminium angle cut up and drilled. Brass screws reside in nylon insulation bushes, I used two loose spades (as on coils) for the idiot light feed.
Volkenstein
rickosuave1987
Hey guys, just wanted to say thanks, I got the wiring hooked up today and the alt is charging great. No more killing the car with my off road lights 8)
Baja
HookIt
MNAirHead
Post by MNAirHead »
GREAT and Congrats..
This electrical and wiring stuff always seems to be the biggest mystery until we "get it."
Any pix??? Would love to see some of your completed trophy work.
rickosuave1987
Completed trophy work? Uh...well...
:lol:
I didnt take any pics of what I did this past weekend, but when I get some ill be sure to post them up. I still have a lot of wiring to clean up and some more stuff to re-do, but I will post pics.
Baja
HookIt
