What advantages to alternator vs generator?
Warner
Post by Warner »
I'm having an engine built and sent my generator to the builder. He's recommending that I use an alternator instead of the generator. What advantages are there to an alternator? What else in my electrical system will need to be changed out once I get the completed engine?
Thanks in advance,
Warner
Glenn
Post by Glenn »
Generators put out 30amps while the alternator puts out 55amps.
If you generator is 12 volts then it's a simple swap and you need to remove the original regulator since the new AL82 alternators have an internal regulator.
volkaholic1
Post by volkaholic1 »
the other big advantage is that generators have brushes that wear & must be replaced. Alternators don't have this problem.
Warner
Post by Warner »
Glenn wrote:Generators put out 30amps while the alternator puts out 55amps.
Glenn, thanks for the ultra-quick and very informative post. You are an assett here!
Warner
PS - I'll let you know how my 2180 (thick walled 92's like yours) does on DRD's dyno when he gets it together!
Warner
Post by Warner »
Warner
I think you have the change the fuel pump too with the offset one.
MNAirHead
Post by MNAirHead »
If you go alternator.. you want a 2 terminal (internally regulated) alternator.. not the Motorola.
Glenn
Post by Glenn »
Ol'fogasaurus wrote:I think you have the change the fuel pump too with the offset one.
Correct.
MNAirHead
Post by MNAirHead »
If you choose to use an alternator... mind if the title is changed to "alternator conversion?"
Could expand to the parts etc.
MNAirHead
==101 Basics - Generator to Alternator Conversion==
Post by MNAirHead »
This post is based on a very smart question
http://www.shoptalkforums.com/viewtopic.php?t=107828
So we all can become involved..
1-What parts are required?
2-What are the common mistakes?
3-Which alternator do you suggest?
4-Any tricks?
5-Did I miss something?
MNAirHead
Re: ==101 Basics - Generator to Alternator Conversion==
Post by MNAirHead »
moved
Boneloader
Post by Boneloader »
MNAirHead wrote:If you choose to use an alternator... mind if the title is changed to "alternator conversion?"
I think the "what advantages to an alternator... " is a valid question--
I understand the fact that a generator is only 30 amps, but what exactly does that mean for my daily driver? Will my battery slowly die if I exceed its capacity?
Is anyone using a generator with good results? If so, how many accessories are you running off it?
Gotta go... I'd better start shopping for an alternator. :roll:
~Troy
