It's common for all of us to just throw new parts at our old car. I'm convinced I've retired perfectly healthy generators. My thought has always been that as long as the engine is out, get a new generator?
1-How can I tell if my genrator is generating?
2-Do I test differently if it's a pre 67 6 volt radio?
FAQ - How do I know if my generator is generating
- MNAirHead
Not recommended to do that if you have an alternator, though - with no battery in the circuit for a reference they can run away and fry.
http://www.vw-resource.com/generator.html
http://www.nls.net/mp/volks/htm/gen.htm
SUbuggy
easiest way is to measure battery voltage with a multimeter with the engine off. shoudl be around 12.4.
start engine. once running, re-measure. if voltage is less than 12.4 you can bet you are pulling down the battery and not charging.
NOTE
sometimes big stereos, lights fans whatever may at idle cause your voltage reading to be low unless you have a BIG alternator. just rev it up a little and you shoudl see system voltage go ABOVE 12.4. this proves your alt is charging.
NOTE
- Badbugtwo
blacktruck
That takes the same connections as polarizing (positive to B+, negative to DF) and the generator should spin smoothly - no jerkiness from dead spots or brush-hopping from an out-of-round commutator. I've yet to meet one that didn't work fine as a generator if it motorized OK.
...do not attempt with an alternator!
