Norwegian Pro Mod motor
Marty
Post by Marty »
Its been a while so I thought I would lay out another project that had been in process.
Recipe:
SCAT 78mm flanged crank with T4 mains and Chevy journals
Autcraft dry sump case
Pauter 5.5 Al rods
Venolia 4" pistons
HEAVILY worked Autocraft 910 heads with 54 x 40 (Ti intake, SS exhaust) with K900 springs (roller)
Custom roller cam
Isky roller lifters
Autocraft dry sump pump
Custom Staggs Racing turbo system
Marty
Post by Marty »
Foundation -
Crank with rods hung -
HEAVILY Auctocraft modified case -
Custom turbo, carb etc -
Marty
Post by Marty »
Heads -
64bug
Post by 64bug »
Damn that looks and sounds amazing!!! by the way is that my motor in the backround???
M3D
that engine
Post by M3D »
that looks sweet what is the cost on a engine like that with all the good stuff in it .
i am looking to do a engine soon that will be as good as the one i have now it must hold up to 26lb boost and make 400+ hp and rev to 8k with out comming apart on me with 7.5:1 CR turbo efi.
i have a 2054cc right now that Jame at state side tuning made up for me back in 96 and it has 70'000 mile on it now and ithink it is time for a new engine :D 8)
www.emeraldperformance.com
panel
Post by panel »
What are those bronze sleves for where the push rod tubes go ?
Marty
Post by Marty »
64bug wrote:Damn that looks and sounds amazing!!! by the way is that my motor in the backround???
Yes.
You want me to start a thread on that????
Marty
Post by Marty »
panel wrote:What are those bronze sleves for where the push rod tubes go ?
DUDE - those are the lifter bores. :wink:
Marty
Post by Marty »
Setting the modified bearings -
Laying in the crank and roller cam -
Marty
Re: that engine
Post by Marty »
M3D wrote:that looks sweet what is the cost on a engine like that with all the good stuff in it .
Well its quite a bit depending on options.
This motor will make and hold 40+ pounds of boost.
konaturbo
Post by konaturbo »
great motor marty, looks like the heads are ready to bolt on but what about the exhaust guides?
Honda's Killer
Post by Honda's Killer »
Why do the retainers have holes in them? Or are they just dimples
CompTurbo.com, Lucas Oil, Pacific Customs,
richie,uk
Post by richie,uk »
Hi marty,looks good,I always wondered about ally rods in a turbo motor,whats your thoughts please,cheers richie,uk
www.rjvolksperformance.com
We make VWs go fast!!!
Marty
Post by Marty »
konaturbo wrote:great motor marty, looks like the heads are ready to bolt on but what about the exhaust guides?
They are a different material and are THICK!
The reason I left them is is because of the HUGE spring pressures. Cutting them down would have left them too short to live under the spring pressure and loads placed on them. These are not ordinary guides either so they will be fine and have already been proven durable on turbo Pauter motors.
Marty
Post by Marty »
Honda's Killer wrote:Why do the retainers have holes in them? Or are they just dimples
They are special Manly Ti ratainers. They are holes.
