1. Construct an intake system that would fit under the deck lid of my Speedster replica, and that would supply the air volume necessary for a 2180cc developing approximately 150 h.p.
2. Construct the intake system using commonly available materials and easy fabrication skills.
3. Have an engine that would run in a superior fashion to the Weber 44 IDFs that were installed. I was after the drivability of a modern FI engine.
I would post some pics of my engine, but since they have to be posted at some other location on the web first, which they are not, it is more than I want to deal with today. My brain is full!! If you want to see some pics, send me a PM.
The common problem in converting large ACVW engines over to fuel injection is in obtaining a runner and end casting system that is large enough to handle the air volume needed. The btlmex castings are too small since they were designed for a 1600cc motor. The CB end castings are likewise too small and need some serious modification work to make them flow. My solution was to use 1.25” ID copper water tubing and related fittings.
The shop tools necessary to fabricate this intake system were a 1 h.p. drill press, table saw with a non-ferrous metal cutting blade, oxygen acetylene welding outfit, arc welder, metal cutting composite blade on my circular saw, rotary files, and assorted hand tools.
I rebuilt the motor in the process. Following are the motor specs, with many parts replaced and upgraded:
· New aluminum super block, clearanced for 82mm crank and 92mm pistons. Machine work performed by Rimco.
· Rev-Tru 82mm, forged, fully counter-weighted crankshaft with Chevy journals
· Chevy rods
· Total Seal rings. Cylinder PSI ranges 150-165
· Pistons match weighted to within 1.0 gram of each other
· Full flow oiling system
· 1.5 quart extended sump
· 8.1:1 compression ratio
· Engle V-26 camshaft with new lifters. 297 degrees duration.
· 1.4:1 High Lift ratio rockers
· Hi Torque starter
· Chromoly push rods
· 35.5 x 40 valves
· Silicone bronze valve guides
· Ported and polished, welded-up VW heads, cc’ed to match
· MegaSquirt-II programmable fuel injection
· Large diameter “J” tubes
· 8 Pin flywheel
· Ford EDIS ignition
· 52mm Holley TB
· 20.8 lb/hr. Bosch injectors
· Innovate LC-1 WB O2 sensor
The motor runs cool at a steady 180 degrees, without an after-market oil cooler, while producing an estimated 150 h.p. My goal in building the motor was reliability and cool running, not high horsepower. I am getting to the point that I would rather drive it than work on keeping it together! Also, there are a host of other modifications to my Speedster that are in the planning stage.
Assembling, installing, and tuning a MS-II is not for the faint of heart.
The most difficult parts for me, since I had little understanding of fuel injection systems and no tuning knowledge, was in attempting to understand the MS manuals in regard to the various assembly options and tuning. There is sooooooooooo muuuuuccchhh to read and then comprehend!!
Although I am still tuning the AFR and VE tables, the throttle response is simply unbelievable compared with the Webers. There is no stumble on take-off and drivability is going to be all that I had hoped for. The engine is easy to start in all temperatures and smooth reving. I love the fact that I am no longer spewing clouds of unburnt fuel into my garage when the engine is started from cold.
I screwed around with the GM IAC for weeks, until it ceased to function at all. Rather than waste more time and money, I decided to go manual control with the air.
For you folks who have an interest in my intake manifold dimensions, they are: 1.25” inside diameter runners, 22” long. Plenum inside diameter is 3.8”, with an interior length of 7.65 inches.
I want to thank Bill Steele for his advice and encouragement in this project. He kept telling me that I almost had it completed, no matter how deep I was in frustration at times. Thanks to those truly skilled and knowledgeable individuals on the Fuel Injection forum in Shop Talk Forums, there is a wealth of design and component selection information accessible in search mode. The gurus on the MegaSquirt forum are vital when problems are encountered with that system. Gearheads rule!!
I hope that my success as a newbie encourages others to embark on such a project with their ACVW. These timeless designs will keep getting better as long as there are people willing to adapt the newest technology to them.
Chuck Roach
Wichita, Kansas
[email protected]
