Shoptalkforums.com
For Your Air Cooled Pleasure!
It is currently Tue Feb 09, 2010 6:20 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Turbo 36hp vintage Bonneville motor
PostPosted: Thu Nov 16, 2006 5:03 pm
Offline
Attached are some pictures of a turbo 36hp VW 1200cc built for a vintage race VW class of land speed racing called the New Age class. The motor must be 36 case with stock stud spacing and anything goes in this class. Bore, stroke, Okrasa heads, cams, fuel injection or turbo. I chose to build a turbo 36, blue printed, 8 doweled but stock cc just to see how it would respond to a turbo.
I used a T-2 Sunbird turbo, built an exhaust system with 1 1/2" OD mandrel bent tubing, a very smooth, alternate firing pulse style header and a 2 1/2" smooth exhaust from the turbo out and under. This is a total hideaway system, stock deck clears everything, no cutting anything on the car. I tried to make this clean and efficent and to the standards of Marty & Matt. I have been following this site for a long time and it's just great.
We ran this car at the September Bonneville meet without any R&D on the road (ran out of time like racers do) in Burly's retro sedan. We only got a few passes in before the rain storm hit. We did OK, not super, but learned a lot. At that altitude, 5-6000ft, the engine vacuum was down 3-4" and the turbo would barely make boost. The Harley carb is a CV type so low vacuum & wide gear spacing really killed the power. I have the motor back in Iowa now, in a test car and are doing R&D now. I went to a real carb, Solex single 32, changed turbos three times and it's getting a lot better now.
What I'm realizing is that the turbo size is very critical on an old poor breathing style motor. There is not enough air flow through the engine to drive the turbine. This is not as easy to make it run as it looks on paper, however I will stick with it until I solve it.
BvilleTom
Motor:
Car on the flats after the storm:
Top
 Profile
 Post subject:
PostPosted: Thu Nov 16, 2006 5:33 pm
Offline
nice set up and great pixies...would like to see more updates on it
Top
 Profile
 Post subject:
PostPosted: Thu Nov 16, 2006 7:19 pm
Offline
I just received my new issue of Volks World today and I was impressed with the feature of your car. Low and behold I log onto the STF and you've posted pic's! :shock: Great job!
Top
 Profile
 Post subject:
PostPosted: Thu Nov 16, 2006 8:19 pm
Offline
Do you have to use the stock intake pipe? I have a singleport 1584cc with 35 x 32 valves and it is making close to 200 hp with 15 pounds of boost . The key is to open up the heads so that the valve is the restriction if you are keeping the stock size valves. My intake ports are approx 34mm in diameter. I am using a 110 cam equivelant and a dellorto 40 sidedraft. I used JB weld to fill in the voids on the heads. So far so good.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Leisureking and 0 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
