This is what it looked like when I got it backin Oct. 2002
I stripped all the old paint off.
Replaced the passenger heater channel.
Replaced the floor pans
Cut front and rear clips off and install all fiberglass pices.
Did all the body work.
Removed all switches and rewired all electrial to toggle switches (thanks to Speedy Jim for your help on this)
Installed front seats out of a 1996 dodge avenger. made new seat brackets.
Install new 1641cc DP engine.
New Goodyears all the way around on white spoke wheels.
New rubber and seals on the windows.
When I got the car (for free I might add) It had a new tranny, new brakes, new shocks on front, new tires. The original engine had a broken rod or
something as It did not run.
So far the only thing I did not do was paint it. I had no place to do this so I had a local shop spray thre base coat/ clear coat.
Install all new VDO guages.
Heres a pix of the dash.
Jeff
