Go to zero lift. Screw your adjuster out until it bottoms on the back of the rocker. Then open it about 1 1/2 to 2 turns. Adjust your pushrod until it is at zero lash and then take your rocker to HALF lift. Snap a shot like the ones you already have, and then a shot of your adjuster and all. As sideways a shot as you can get, like this:
The one in my shot is not set up right, but that's the shot. What you want at half lift:
* Tip centered as much as possible on the lash cap (vertically)
* Adjuster as in-line as possible with the pushrod
* If you draw a line through the contact point of the rocker to the lash cap, perpendicular to the valve stem length, you want it to bisect the rocker shaft right at centerline.
You'll not get all three of these perfect, most likely, but something close to all of them is good. That's how I did mine, and after 18K miles with dual springs, my guides, lash caps, and rockers are perfect. Once you get these things set, by using the right shims under the rockers (I didn't need any shims), then you measure your pushrod length as you have it set. Do not use the adjuster to change anything.. it doesn't. But having it 1.5 to 2 turns out ensures that you will have room to adjust valves and it won't be so far out that rocker rotation will cause a lot of vertical motion of the pushrod on action.
