Auto Trans Oil Pump
- Ghia Nut
Auto Trans Oil Pump
I have an old auto trans pump in tact and in good working condition. If I do get to build a turbo 2.0l I was wondering if this would be a good choice for runing the oil to the turbo. Is there anything I should have done to it?
- mightymanx
I would not use it to run oil to the turbo they are usualy used to remove oil from the turbo (scavange) and return it on a low mounted turbo set up.
for supply use the oil pressure sender hole install a t-fitting (1/8 NPT from any hardware store works well) one to the turbo one for the sender.
I drain it to the 1/2 head just plumb it to the valve cover like a breather hole on the front (pulley side) and you should be good to go.
- mightymanx
That one should be for large-passage case and four-rivet cam (the change came in mid`71)...all billet performance cams are three-rivet, to use that pump you'd need to have a stock 4-rivet cam reground.Ghia Nut wrote:Its from a 72 autostick ghia that I have just sitting around...
Check the depth of the body against a known new standard pump - the 4-rivet P/N is 111 115 107BK, the 3-rivet is 107AK.
- GS guy
Machine a custom billet steel intermediate plate with outlet fitting for the oil to come out, then fit a longer gear shaft for the auto stick gear drive, running through a bronze bushing. I did one of these but never used it. Fitted to a Berg 26mm pump.69bajakid wrote:what do you do for "full flow" oiling when you run a autostick pump?
Send a pic or 2 if you want to see how it works/looks.
Jeff
- 69bajakid
Yeah please do send a pic..
Post it or email me.. [email protected]
Sounds like a good idea for a multi stage OE style pump
..i wish i did that to my CB turbo/EFI kit..
Cale
Cale
- sideshow
- GS guy
I put a few pics up on my Yahoo photos pages:
http://pg.photos.yahoo.com/ph/estreme1/ ... pg&.src=ph
3 pics of the pump.
In hindsight, I think modifying the case as shown above would be a much easier (and possibly better) way to get full flow with the auto-stick pump. On the modified pump, the plate that provides the FF outlet extends the pump out away from the block about 1/2" (or was it 3/4"?) or so. Not sure if this would cause interference with a CB exhaust system or turbo?
Jeff
3 pics of the pump.
Jeff
ourkid
I've just fitted a autostick pump on my set-up,after using a 12v pump for a while.It is from a 73 Ghia.(my turbo is low slung too).
Full flowing caused me major headaches for a while and the solution i came up with is still a bit of a compromise but i couldn't think of any other way of doing it because i had already assembled my case.
Luckily one thing i had done during strip down was to drill and tap both front passages.
My oil comes out of the top passage because i plugged it just downstream of where the oil pump outlet passage intersects it,using a 3/8 inch bsp plug,loctited in place.My plan was to then return it to the bottom passage but access was a bit tricky so i returned it underneath by making my own version of the return adaptors that screw into the oil pressure regulator hole.Unfortunately this means removing the spring and plunger so all the oil goes through the cooler all the time but because it's not an uprated pump i should be ok.
These return adaptors cost about £50 over here but i just tig welded a -6 fitting to the stock plug then drilled through. Ade
