930 Stub axle and CV's
- kcnaz
Ok I am reaching out into the dark side blindly here so be kind. This STICKY thread "930 Stub axle and CV's" has no info posted to it, or my browser can't find it.......so here goes.
will 930 stub axles and drive flanges accept the 934 cv?
What is max angle for 930's? What is the axle spline count?
What is max angle for 934's? What is the axle spline count?
Offroading vicariously
- Getrdone
I just had a digital protractor on my 930 shaft. Kinda hurt at first but they "felt good" @ 26.6. Typical from what I remeber is 25. Depends on prep. Mine are "race prep", but that term is in the eye ot the prepper. I limit @ 26. Speaking of which my straps are streched out and it reminds me to check them prior to each trip. I"ll double check in the morn that is what I have and I will try to count the spliney things. I do know there are alota em.
I edited my angle. they are sitting at the 26.6 mark now after the bus trans swap. Wheels spin free with no clicking.
- Crash
The 934 CV's are much bigger and don't have near the angle that 930's do.
-Mark
-Mark
________________________________
Mark "Crash" Johnson
Blind Chicken Racing
www.blindchickenracing.com
- Leatherneck
Re: 930 Stub axle and CV's
Still looking for answers.kcnaz wrote:Ok I am reaching out into the dark side blindly here so be kind. This STICKY thread "930 Stub axle and CV's" has no info posted to it, or my browser can't find it.......so here goes.
Also added this thread to the 930 info thread, thanks for bringing this up Keith.
- Leatherneck
Zancat, thanks for the info. In my opinion key word is should, not to often does it happen though.zancat wrote:930 axles are 28 spline, 934 are 33 spline. A 934 CV will not fit a 930 flange and visa-versa.
As mentioned CV angles are determined by HP and prep. Out of the box german 930 CV's should be good to 25* max.
Zancat
Computer tip: if you press the alt key while holding it down type 0176 you will get the ° symbol.
- rickosuave1987
I know you will hear a million different angle measurements for 930, but my Lobro (german) 930s with a t-1 box and 3x3 arms bound at aound 22
Baja
HookIt
SuaveRacing FaceBook
HookIt
- Hedrock
- Getrdone
- zancat
Was that a verticle measurement or absolute total angle?Hedrock wrote:rickosuave1987 wrote:I know you will hear a million different angle measurements for 930, but my Lobro (german) 930s with a t-1 box and 3x3 arms bound at aound 22
My Mahle (German) right out of the box click at 22°. I plan to work on them just a tad to see what happens. I have a 5 rib and 3x3's.
See the down and swept back angle thread......
http://www.shoptalkforums.com/viewtopic.php?t=119847
°WOW°!!!! Too cool!
Zancat
Zancat
- Hedrock
zancat wrote:Was that a verticle measurement or absolute total angle?Hedrock wrote:rickosuave1987 wrote:I know you will hear a million different angle measurements for 930, but my Lobro (german) 930s with a t-1 box and 3x3 arms bound at aound 22
°WOW°!!!! Too cool!
Zancat
That is the put it together and try it Hedrock and Letherneck method. We did not figure in the rearward angle...
With it as is I have right at 15" of wheel travel.
°°... Still works
