Dellorto 36 DRLA
MrGolf
Dellorto 36 DRLA
Post by MrGolf »
Has anyone ever ran one of these on a stock 1600 DP. I tried this carb before along with a number of different jetting configs. Was able to get it to idle but when I cracked the throttle it had a big hesitation. No heat tubes to the manifold.??????? would like to run it if it can be done.
Barry
Post by Barry »
are you talking a single carb??
What vent are you using??
Would be preferable to have heat, but "should" be able to run
Glenn
Post by Glenn »
I ran dual 36 DLRAs on a 1600DP back in the later 70's. The only other upgrades were 1.4:1 rockers, header, Bosch blue coil and 009.
It ran great.
Glenn
74 Beetle Specs | 74 Beetle Restoration | 2180cc Engine
"You may not get what you pay for, but you always pay for what you get"
http://www.DasVolks.com
MinamiKotaro
Post by MinamiKotaro »
Dual 36 Dell'ortos are the best carburetion for a 1600.
'67 Beetle, 2276
MS-1 v3.57
Croatian VW Club
Post by Croatian VW Club »
Can anyone tell jetting numbers for Dellortos on 1.6 stocker??
Doktor
Post by Doktor »
No one knows ? :D :wink:
Hrvoje-ZD
Post by Hrvoje-ZD »
Yeah I would really like to know also about jets on 36 DRLA :idea: Anyone :?: :!: 8) :D
Barry
Post by Barry »
On a stock 1600 with IDF 36 Webers i have used
32 vents
135 mains
F11 Emulsion tubes
45 idles
180 airs
Sweet and economical
ruffbiker
Post by ruffbiker »
anybody ever tried dells on a homebrewed DP 1200? Got all the parts at home, would be the most cheap solution for me and there are slaloms over here with a category '1200'
egspot
dell 36s
Post by egspot »
Barry wrote:On a stock 1600 with IDF 36 Webers i have used
32 vents
135 mains
F11 Emulsion tubes
45 idles
180 airs
Interesting....
firebug
Jetting 36Dells
Post by firebug »
Here's what I'm running on my 1600:
Vents 30, Idle 55, Mains 125, Air 180, Acc. Pump 33, Emulsion 9164.3.
MrGolf
Dellorto
Post by MrGolf »
Firebug,
Are you running a single 36 DRLA Dellorto. I have this carb and alot of jets but could never seem to get it running good. Thats why I wanted to know if you are running a single 36 DRLA......Thanks
Bruce2
Re: dell 36s
Post by Bruce2 »
32 vents
135 mains
F11 Emulsion tubes
45 idles
180 airs
Interesting....
Jet values for Webers are meaningless compared to Dellortos. Don't try to compare them.
MrGolf
Dellorto
Post by MrGolf »
Not interested in a Weber. I have a single 36 DRLA and want to know if the info firebug posted was for a single 36 DRLA on a 1600 DP. It is sitting in my basement and is in great shape. Had it on once before. Got it to idle but went on its face when I cracked the gas.......Thanks anaway Bruce. I do run dual webbers on my other bug. I just have this carb.
Bugfuel
Post by Bugfuel »
Firebugs jetting is for duals, I'm sure.
For a single carb application, you have to jet MUCH richer.
You can keep the 180 airs if that's what you have.
What distributor are you using? That has a major effect on off-idle hesitation.
Try 60-65 idle jets, and 150-160 mains. Adjust accelerator pump too to see where it responds best. The acceleratr jets are removable too, you can get those in different sizes as well.
And you most likely will need to spend some time tweaking the ignition curve to match the carb.
And you definitely need intake manifold heat, if you want decent driveability. Otherwise forget the whole thing and go back to stock carb. It really really works best in an otherwise stock engine, when all the parts are correct and meant to work together, and adjusted properly. You can't improve on the design unless you re-design the whole thing, replacing just one component is a sure way to cause more grief than gain.
Jan
