Front lowering using BMW coils and Koni shocks
E30 spring
Hi Wally,
May I know is that the stock E30 spring or lowered E30 spring? Where can I buy the koni shock from?
Cheers,
Cheers,
- Wally
Re: E30 spring
Its the very stock spring! You want the softest spring from the lot, whatever that is. Mine was (probably) from a '91 car.VW411L wrote:Hi Wally,
Cheers,
Koni shocks (and all other makes) for the 411/412 are long out of production. I got lucky
Welcome to the forum!
May I then ask what your car looks like and what your plans are?
Greetings,
Walter
Re: my 1969 411L hatchback
Hi Wally,
Here is the link to my 411. I am think to lowered it.
http://www.nzveedubnuts.com/viewtopic.php?t=1587
Cheers,
Cheers,
- Wally
Your wheels made me smile, as I had those on very recently. Just look at the back of the rim: all data about size and manufactorer are there.VW411L wrote:Hi Wally,
Cheers,
"Made in England by M.A.G. Industries"
Old picture with MAG rims
Very nice early car you have there!
Greetings,
Walter
Hi,
Thanks.
Your 2 doors type 4 look nice with those wheel on. The black detailed looks cool.
Cheers,
Roger
Thanks.
Cheers,
Roger
Type 4 Fan
Hi,
Do you have any photos of your type 4s?
They sold quite a few to New Zealand from 1969. They came from Germany. Later date from 1972 some wagon/estate came from Souh Africa. They are unpopular in New Zealand. In these days most of them been wrecked as a parts donor. I think they only has less then ten now. What a pity? They are quality built car - roomy, comfort, fast, solid and don't see them everyday.
Cheers,
Roger
Cheers,
Roger
- ubercrap
I have a picture of the other one somewhere...The wagon is pretty nice, just finishing up a few things on it to make it a good driver, the Marathon Blue car is very complete and straight, and needs moderate repair, shouldn't be out of the question-soon baby, soon, I promise...
- raygreenwood
Parts whore! .....
.....Actually, i was almost as bad at one time. I had one main 412 I was working on, one spare I was comtemplating and parts from about 8.
Now I have but one (and lots of parts)......and it will be sweeeet when done. Theere are so many critical small things to create fromscratch that I had to limit myself to one very good specimin. Ray
- ubercrap
These are just the cars, you haven't seen the parts! I've been letting some parts on ebay go to other people... I want to see more of these on the road. But, if I didn't pick up these particular cars and love them, I'm not sure there would have been anyone else? They will at least be stored indoors to prevent further serious deterioration.
- Wally
Hey Bill,
It was nice meeting you here. Glad we got to take a ride in the 412S, although it was only a short one
Nice score on the Konis!! Where did you find them?
No, you don't really need anything else afaik. Do remember I have the asymmetrical top strut bolt/bearing housing spacing. I believe they are only there on 8-'73 -> models. Mine is 10-'73.
But no dispair, the Koni's (at least the ones I have) were actually made for the '72 and '73 models 412. The tube-like spacer you see on my pictures is actually to adapt them to '74 models as well
With the symmetrical struts you are on your own as far as making sure you don't have a loose spring when you insert the bmw spring, as I don't have these struts and don't know the exact differences, length and spacer-wise.
BTW: make sure you align the front end after you lower the car! I did mine last saterday and went from considerable toe-out to a nice toe-in. Straight line stability has been restored again
You're over your 9-hour jet-lag yet
Greetings,
Walter
Greetings,
Walter
- Bill K.
Thanks for the hospitality Walter. It was very interesting meeting you and discussing all your projects. Next time I'll bring a real coat...
I got the shocks from the guy in Georgetown (Erich) who has all the T4's. I also picked up NOS ball joints, a rear sway bar, and some lenses.
I'll be converting to the late super asymmetrical strut mounts using the info here. Wally, did you adjust the Koni settings?
Should I be looking for BMW 325i or 318i springs?
Thanks,
Bill
Thanks,
Bill
- Wally
Yeah, I use the softest setting (compress all in and then turn left all the way, then a quart or half a turn out again).Bill K. wrote: Wally, did you adjust the Koni settings?
Thanks,
Bill
No, not the 6-cyl springs: probabbly too thick in coil diameter. Mine are from a '91 model 4-cyl IIRC, but use the smallest motor E30 4-cyl model you can find. 316 or s/th.
My set up is already pretty hard, so be carefull on the spring-thickness. 12.2 mm is original and also the spring coil diameter of the 4-cyl E30 springs. Mine had some white stripes painted on them.
Good for you that he wanted to sell those after all! I finally located some original, but complete 3-point automatic seat belts and a friend over here had some seperate NOS belts, so I am safe again
Regards,
Walter
